Question about Fisher and Paykel GWL11 Top Load Washer
I have been given a gw703-u smart drive washer and it was left outside for some time. I have some yellow lights on a couple of the cycles and some red lights on some of the options. The cover for the buttons is lost too so I only know from some downloaded pics what most of the lights are for Can anyone help sort this out? Craig
    Brigadier General:
  • 6,277 Answers
Quick reply- methinks you could do with a manual ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number! You could also try the manufacturer's web site direct.
If this has assisted you please score accordingly.
Thanks and good luck!
John C.
Posted on Apr 11, 2011
Testimonial: "Thnaks I already found one. it started working all by itself though. Thanks Craig"
Smartdrive9 fault codeshow to read and desipherthanks
turn power off on washer not at wall. hold the water level button down and press power button on. then it should beep 2 times. let buttons go. tell me what the lights are that are on.
Jun 19, 2013 | Washing Machines
Fisher & paykel washer GW703 only letting water in spurts. takes forever to fill.
Hi just read your posting. Sounds like you have an out of balance switch problem.This is the most likely cause on the information you have posted. 80% of the time it is the switch and about 20% of the time it is the rotor sensor which is attached to the motor.Just a question or two. Does your machine stop during filling and light up a series of lights and it starts to beep.If it does ,from left to right is it the 3rd and 6th or 1st and 7th etc please reply and I can guide you throe what action needs to be taken.
Jun 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Spin cycle is not working
one possible problem the lid swicth might have broken but if you hear a moter noise when it trying to spin the swictch is ok you can verify
if washing machine agitates during wash cycle
if no agitation newer design has a drive coupling between moter and transmission lean machine back
you will find debries center of machine about 8 inches back usually black rubber the drive coupling
has 3 pins on each outside peice that fit into the center bushing lean machine back have second person for safety unplug machine to change drive coupling there are two clips that hold pump to top of moter remove clips slide pump off shaft remove two screws from top of pump clips unplug wiring harness
undue clips remove moter drive coupling peices can be remove by pulling or can use large flat blade and work from oposites sides till plastic parts come off
reassembly place outside parts one on transmission one on moter install center part on transmission side
line up pins from moter to line up with 3 holes in center part normally top clip i install first so gravity assist with install of bottom clip reinstall screws plug in harness line up pump with moter shaft and reinstall clips run check if no noise from moter when lid is closed then lid switch might be bad the new style of washer is front serviceable there are two screws bottom outside corners of panel remove
light pressure pull panel forward then lift is hinged at
top back roll back there are two brass clips catch front of clip with flat blade screw driver and move top of handle toward back of machine clip will pop off wiring for lid switch on top of case needs to be unplugged outside case will tilt toward you then can be lifted off alignment tabs at bottom front there are two screws where lid switch is held to top of case can be seen when case is removed good luck ron
Dec 10, 2009 | Kenmore Washing Machines
Fisher and Paykel smart drive 708 will not start
unplug the washer and wait 10 or 15 mins sometimes it takes time to reset the program
Aug 23, 2009 | Washing Machines
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Beeps every second, and won't work at all Fisher & Paykel Excellence 7.5 Smart Drive
hi camille
can oyu turn the bowl manually if it is very tight then it is most likely the bearingand it will need tobe serviced
cheers grant
Oct 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Machine wont work
Your machine probably needs re setting hold power down for 60 seconds see if that works
Apr 15, 2008 | Fisher and Paykel Fisher & Paykel Washer
Despenser cup - Kenmore dish washer
hi
the dispenser will always open when the washer goes through it's regular cycle. I would recommend to only use powdered soap, that is what the washer was designed to work best with.
Mar 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Fisher & Paykel GW703 wont stop!
It sounds like your machine has been programmed to automatically run through the various cycles continuously. Most likely in error.
Oct 07, 2007 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
226 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
