Question about Bernina 1008
I bought a used Bernina 930 Record sewing machine a few months ago and I had it serviced and it works great except that the foot pedal doesn't do what the instructions say it should do. It should stop needle down upon retapping the foot pedal but this machine insists on stopping with the needle up 100% of the time I tap. Any clues what the problem is? I own a Viking sewing machine as well and that machine stops needle up and also needle down when I lightly tap on the foot pedal and so I'm thinking that the Bernina should operate just like my Viking. Am looking forward to your input. Thanks. Maria
  • busterang Apr 14, 2011
    I think there must be something wrong with the foot pedal. It just will not react when I press on the back of it and I've tried dozens of times trying to get it to move the needle to the down position. Maybe the wiring is damaged somehow??? I do sew on the machine and love it's performance but I really wish I could control the needle position like I do my Viking machine.
    Maria
  • 3,018 Answers
Let me say that is a fine sewing machine. I have the fix for your issue. Your sewing machine has an electronic system that takes the needle to it's highest point when ever you take your foot off the pedal, the front side of the pedal. If you tap the back of your pedal with your heel the electronic system will take the needle down into your work. If you again tap the back of the pedal again with your heel the needle will go up. In short the front side of the pedal is for full speed sewing where the needle can stop in the full up position at anytime. If you want more direct control of your needle then simply use your heel on the back of the pedal.
Regards, Tony
Posted on Apr 12, 2011
  • Iron
    Iron Apr 14, 2011
    I understand. Yes, if you cannot control the needle with the back of the pedal then something is definitely wrong with the pedal of the wiring. Pedals, like machines, have to be tended to from time to time. I would suggest going to your neighborhood sewing/vacuum shop and have the pedal looked at. Fixing those are usually not expensive as there is not a whole lot to them pedals.
    Regards,
    Tony
Is bernina 930 a low shank or high shank machine
Bernina has feet that are specific to their machines only. They have old and new style feet depending when the machine was made. You cannot put generic low, high, slant or snap on feet on a Bernina sewing machine.
Jul 13, 2017 | Bernina Sewing Machines
Re Bernina Record 930 Sewing Machine,with an inactive Mother Board.
There is a Yahoo Group called BerninaThirtySomethings that would probably be very beneficial. A lot of members are very knowledgeable users or former technicians.
Dec 06, 2016 | Bernina Sewing Machines
I am looking for a bernina 930 service manual. I dropped the feed dogs and they will not come back up.
Most likely they have seized due to lack of regular oiling. I have used the following method on several older seized Berninas with great success. Just be sure to NOT get any oil near the 930 basting stitch mechanism (about the middle of the needle bar) or it will most likely lock the machine.
Wheel on right side that controls the needle up and down is very tight...
This is a diagram for the Bernina 830 Record, but it will give you a good idea of what & where to look for oil ports.
I've never used this source (use at your risk):
Bernina record 930 electronic service manual
Nov 25, 2016 | Bernina Sewing Machines
My Bernina "Record" of 1972 suddenly stitches away without foot pedal command, infact same with pedal unplugged Only way to stop is cut AC power
Something with in your machine seems to be shorting out. Since it is many years old I suspect you have wires that the insuation is rotten and making a short. I have seen this before. Should get it repaired if it's worth it. You could be shocked or hurt.
Oct 21, 2016 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
How do you fix a sewing machine foot pedal for Bernina 930?
You could open it and tinker around, but since those are very expensive controls to repair once a customer has "tinkered" with them, I would suggest bringing it to a Bernina repair shop.
May 13, 2014 | Sewing Machines
What is the difference between a bernina record 930 and just a bernina 930
At the present time, Bernina 930 Record and Bernina 930 are the same machine. Although, technically the name is Bernina 930 Record, referring to the mostly mechanical sewing machine produced in the 1980's. They are very coveted machines and one of the more popular models.
However, Bernina has, in the past few years, begun producing computerized machines and labeling them with the same numbers of older mechanical machines (makes things very confusing), ie Bernina 830 Record vs Bernina 830 computerized model. At this point in time, Bernina has not yet produced a computerized 930.
Jul 08, 2013 | Bernina Sewing Machines
I have a Bernina 830, bought in 1978. When I depress the foot pedal, nothing happens. Power is on. Do I need a new pedal?
I've just fixed this problem by replacingthe main capacitor in the foot pedal. I have a Bernina 830. I needed a soldering iron, and I had to buy the right capacitor, but it fixed this exact problem. Btw, a few months ago this problem initially appeared (on my machine) as an issue where the speed was either zero, or full speed). After a white it wouldn't work at all.
Jul 23, 2010 | Bernina Sewing Machines
Sewing Machines Logo
275 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
