Batteries not charging, battery charger works, is there any fuses that could need to be replaced?
    Sniper:
  • 66 Answers
No such fuse exists....
if your battery is old one.... then surely it has gone completely dead.
if it is new and under warranty.. then it will be replaced freely by the vendor.
Posted on Apr 11, 2011
Batteries replaced. Why can't I get it to charge?
Hi Judy, have you checked the wiring of the batteries , does the power chair work ? if not check how the batteries have been wired..
the charger cannot see the batteries , check the reset button and the fuse for the charger line ..
Regards
Rob
Oct 08, 2015 | Pride Jazzy Select Gt With 2 Batteries In...
What makes the on board charger not work an how cah it be tested to see if it is good.
There is a fuse in the charger and another in the chair for the charging circuit. Poor connections to the controller and at the batteries will do it too. If the batteries have been completely discharged, then the onboard charger does not have enough power to start recharging them. If that is the case, use an automotive 12 volt charger that has no automatic charging circuits in it to charge them individually. That means removing both batteries from the chair and connect the charger to one battery at a time. You can test the charger with the batteries disconnected and measuring the voltage on the wires you just took off the batteries. The voltage should be 28 volts or so if the charger is working.
Jun 29, 2015 | Jet 3 Ultra Power Chair
Light on the charger is not on when plugged in n
If the red light on the charger is not on when plugged in then the internal fuse has blown. This can happen if the batteries have been drawn down too far for the charger. If the batteries are really discharged too far, then you'll have to use an automotive style charger to recharge the batteries individually. Do not use an automatic charger. The last time I did a recharge of a depleted battery using an external charger it took 3 days (72 hrs) of continuous charging to recover the batteries. If this doesn't work then the batteries will need to be replaced as well as the fuse inside the 24 volt charger.
Oct 19, 2014 | Health & Beauty
I am charging my scooter and it is beeping what do i do
Charge without the key on. Make sure your charger is applying power to the scooter. It may have a blown fuse or some other internal problem. If your batteries were totally discharged your charger will not recharge them. You'll have to charge them individually with an automotive style battery charger that is NOT an automatic charger. It may take 3 days continuous charging to recover enough charge before your scooter charger will continue to charge until the batteries are fully charged. If this doesn't work then the batteries will never take a charge nad need to be replaced.
Oct 15, 2014 | Health & Beauty
Micromax x272 charging show but not charging
Hi, so it telling you it's charging however the scooter shows no charge once the charger is disconnected ???
1. First of all , is it possible to try another charger ? or test on another scooter.
2. If the charger proves to be okay, it's starting to look like the fault is with the batteries themselves, batteries can fool certain chargers into thinking they being charged when it fact the resistance inside the batteries have become too great.. They need replacing,...
3. Another issue could be the charger socket or the charging circuit to the batteries..
( is there a fuse ? )
Regards
Rob
www.gewizrepairs.co.uk
Jan 09, 2014 | Pride Line Rally Scooter 3 Wheel Viper
I am plugging my charger in and it is not charging the batteries
There are 2 charging and battery related fuses on this model that should be checked and if burnt open replaced with the same color and fuse type. One fuse is located under a rubber boot near the charging port. Use needle nose pliers or your finger nails to remove and inspect. The second fuse is hidden under the battery box. Pull up and out to remove the battery box and inspect the fuse in the base underneath. If both of the fuses are OK open the battery box and check all the connections. You will need a long phillips #1 screwdriver to do this. Hope this helps
Aug 05, 2012 | Pride Mobility Products GoGo Elite...
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
The chair won't power on and the batteries won't charge. I know the charger works because I have tried it on another chair. When I plug the charger into the chair the light stays green and nothing...
After you changed the batteries, did the power chair sit unused for several weeks? It sounds more like a battery or fuse issue than a charger issue. If there are blinking lights when you try to turn the power chair on (not while attached to the charger), or it comes on then goes back off by itself quickly, there may be something else going on.
1- The green light on the charger is telling you that the batteries are not accepting any more power, either they are fully charged or they have oxidized/gone solid from sitting without being put on the charger for too long.
2-The scrolling lights on the controller when the charger is plugged in just confirms that the chair is connected to the charger, so it sounds like everything is connected properly and working. The horn will work fine when it is attached to the charger as it is getting power from the wall outlet.
3- If it was a fuse issue, the lights would not come on at all when the charger is NOT attached, even after the battery has been fully charged, which is what it sounds like is going on. The fuses can blow if you operate the chair on a slick surface or one of the drive tires spin out. The batteries will be fully charged but because the circuit is not complete, the chair will not power on.
I recommend checking the fuses and changing them if necessary. You are in luck because this is a relatively easy and inexpensive fix as they are standard automotive fuses found at any auto parts store or even Walmart for around $2 each (you need 2). The fuses are located inside the gray battery covers under the seat, attached to the leads connected to the battery cables. The straps holding the covers on the batteries are tight, you may want to use a flat head screwdriver to help release the clips. While you are down there, inspect the tread on the tires, if it is worn or slick it may need to be replaced for safety.
I hope this information is helpful to you- good luck!
Dec 17, 2010 | NRS Hoveround MPV 5 - Used Power...
My scooter battery won't charge. Felt mild shock or short when attempted to insert connector. That seemed to disable the charger because the charger powers on, but will not run the charge to the...
Make sure that the charger is fully connected to the scooter; ususally the controller lights will go slowly left to right to indicate it is charging. Make sure the charger is plugged directly into the grounded wall outlet, not into an extension cord or power bar. If the charger is not being recognized by the scooter, you may need to replace the charger, or at least the power cord to the charger.
If your scooter has been sitting unused for a while? If so, the batteries might not charge anymore and will need to be replaced. Contact the manufacturer for a service call or troubleshooting over the phone.
Nov 04, 2010 | Pride Mobility Products Go-Go Elite...
Batteries not charging - just replaced with new -amp meter dosent move while plugged in. Old batteries were dead and owners manual says charger will cease to work when batteries die and to contact pride...
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
May 07, 2009 | Jet 3 Ultra Power Chair
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
