Question about Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor
Sears YT 3000 42" 21
    Brigadier General:
  • 3,911 Answers
Oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Posted on Apr 11, 2011
  • cohrenich Nov 10, 2013
    Thank you, but it started two weeks ago. It has not sat for an extend period.
Www managemyhome com
bad safty switch or shorting pto if pto replace it but i think one of your safty switches is bad
Aug 26, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
There is no spark to the spark plugs. Fuel is good, Engine spins but will not start.
your switch could be faulty- underground the ignition switch and turn engine over Looking for spark
Nov 02, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
My engine turns but does not start i am getting spark at the plugs i dont think there is enough fuel being pumped in
Try getting a can off carb cleaner or brake cleaner and give it a good spray in the throttle/carb this will likely do the trick.
Jul 09, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My Briggs Vangard 18hp twin V has problems starting. I replaced the starter solinoid but it is still a no go. I can jump the solinoid and get the starter to spin but no fire to the plugs, Any ideas?
This is most likely being caused by one of the safety switches cutting off current flow to the solenoid. turn the key on and jump the solenoid and see if you get spark to the plugs. If so you have a safety switch issue...one is under the seat, one is on the clutch pedal, one is on the reverse position and one is on the blade engagement lever. hope this helps you
Dec 01, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor Logo
935 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
