Question about Whirlpool Refrigerators
We have a freezer on top model #ET8CHMXKTO5 at our futuer seasonal home in Florida. We have been here just three times (2 weeks at a time this past year).The appliances came with the house and is approx 5 years old. My brother/sister-in-law bought in the same development 5 years ago, has the same appliances and are experiencing the same problem. The bottom, inside, of the refrigerator fills with water dripping from the freezer somehow. I called a repair man last December (not whirlpool/sears) as we don't have original paperwork cannot prove it under warrantee or whatever. He came out said it is a common problem with Whirlpool refrigerators. The freezer freezes up in the back line and therefore drips INSIDE the frig. He removed the back of the inside of thte freezer and using a hairdryer defosted the ice. We return now in April and the bottom of the frig is FULL of water! That is just sitting here with no one opening or closing the frig or freezer! What is the common problem and how do we have it repaired to not repeat?
22yooper
  • 828 Answers
SOURCE: whirlpool refrigerator with freezer on
The drain line that comes through the casing may be plugged or the trap at the bottom of the hose where it drains into the drain pan under the refrigerator may be plugged. If water is freezing it is because it is being held back by a restriction.
Posted on May 09, 2008
  • 958 Answers
SOURCE: water leaks from inside refrigerator
could be ice is forming at the vents already.
even though it is a frost less refrigerator, in some instances, you may want to defrost it manually or leave the door open for 1 day just to be sure that every ice in the fridge has melted. then plug it back in and observe it.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
  • 148 Answers
SOURCE: water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Posted on Jan 02, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
  • 5 Answers
SOURCE: Maytg Top Mount Freezer drip tube leaks into bottom of Refrigerat
Just had this problem a few weeks ago. tube from freezer was frozen solid 1-2 feet down from the freezer. Empty EVERYTHING out of the the Fridge and the freezer into coolers or other suitable 2-4hr container(s). Unplug the unit and use a hair blow dryer on the coolest warm setting. If it's too hot it may melt plastic or styrofoam parts. As long as long as you have everything out and it's going to be at room temperature for a while, why not clean it totally out with fantastic or your favorite cleaner. Once your sure the clog is gone from the tube, put it all back together, plug it in and stop being a slob and keep it clean!!!! hehehehehehe
Posted on Sep 08, 2009
Why is the top of freezer frosting up
The door gasket is leaking around the top of the door. Air getting in past the gasket condenses in the freezer causing the ice build-up.
Sep 07, 2014 | Freezers
My freezer keeps getting frost in the back. When this happens, all the temps in my feezer and fridge go up. Fridge is at about 45 and freezer is at 4. This is the second time in three weeks. What should I...
some component of the automatic defrost system is defective watch this video :::pay special attention to the part about the defrost thermostat since itthe most likely cause with frost built up in the freezer the defrost t-stat should have continunity (the circuit to it should be closed)
here is the link for the video,copy and paste it into your browser if it doesnt link automatically.....http://youtu.be/TnRKj7_BtNw
Jul 20, 2011 | GE Profile Arctica Stainless Steel Top...
Water is slowly dripping from the top of Frig.
The water is coming from the defrost cycle in the top of unit . It drains down at the back of the light cover into a tube at the back. Get a phillips screwdriver and take it down to be sure tube is inserted properly. Get model number and go to.appliancepartspros.com to get a diagram.
May 24, 2010 | Frigidaire FRT18B4A Top Freezer...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Leaks after a couple of weeks use
You may need to put a hartford loop in your plumbing between your chlorinator and the heater. The chloriene will back up in the line bad when the pump is off and corrode the exchanger. A hartford loop is simpley a loop than runs low then high above the top of the heater so it can trap gasses in the line and won't let them get back in the line. If all else fails you can use a floater. Be sure to check your PH also. Good luck.
May 30, 2009 | Hayward H Series Electronic Ignition...
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Ice build-up in the freezer of a Kenmore 19 (Top Freezer) refrigerator, and only 60 degrees in the fridge.
there is supose to be a switch or were the ice is making just figure out which way to turn it off or on. then turn it off and see if the ice stop making. if that doesn't work get a new frige
Jan 29, 2008 | Refrigerators
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
