I have a JVC powered woofer model SP pmw 505 without the main control amp. How can I manually switch it on/off adding a switch
billynad
  • 51 Answers
SOURCE: Need service manual or schematic for SP PWA 10
http://www.fixya.com/support/p183860-jvc_th_a10_system/manual-17024/page-70
got there choose the right manuel for you i think you can download it you might need this software to read it www.adobe.com get adobe acrobat reader
Posted on Jan 18, 2008
tech48
  • 624 Answers
SOURCE: I HAVE JVC SURROUND SOUND
Here is a link to the system cable that I think that you are reffering to. The model number of the system you have is TH-M45
The model number you gave is for the sub-woofer only. This is the system cable that is required to connected between the sub-woofer and the main head unit with the DVD changer in it.
http://www.jvcservice.com/store/ProductDetail.asp?Part=QAM0381-001%20%20%20%20
If you can not click on the above link, just copy the entire link and paste it into the address bar of your interent browser.
Since this is the part you want and it is the cheapest place to purchase it, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free technical support.
Thanks,
Dave
Posted on Sep 13, 2008
  • 124 Answers
SOURCE: Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Posted on Nov 21, 2009
SOURCE: no power
are u willing to sell ur faulty sub wooder unit. please email me at zohaibasad@hotmail.com
Posted on May 16, 2010
caroldon
  • 17130 Answers
SOURCE: When switched on at the mains the power light is all that works
If your speakers are making this noise on switch on please disconnect them and check out if they the speakers are damaged by a continuity test of the impedance. It must show the marked resistance without a short. Then you are lucky. Next open the amplifier and check out on the output side and the power side for failure of mains capacitors/ output drivers/faulty coupling capacitors. Connect a resistance loaded test- speakers whenyou do this test .Switch on and put the set on fopr voltage checks from the output to the preamp. By a signal test you will be able to analyse the gain factor of all teh corresponding stages.It might be possible that your amp is old and some electrolytics have dried up.If so put the amp on for some considerable time and confirm if there is response building up on the controls and panels slowly. If so check onthe board for the suspected passive components and replace all suspected capacitors. Also resolder the main pcb for bad connectivity. I am surre this must work but attampt only if your are familiar to doing this repair. Good day
Posted on Jul 19, 2010
Have a JVC sub SP-PWM606 all speakers work except sub. found a blown cap on what I assume is the sub's amp replaced 2 caps- still no sub
Sub woofers are basically mono amps. It's likely that either a fuse has gone, on the sub, due to the blown caps. Or more likely the main power amp device of the device blew the caps. I suspect if you replace the IC or transistor(s) on the heatsink then the device will come back to life.
Feb 04, 2018 | JVC Audio Players & Recorders
Can I hook a jvc powered sub woofer model number SP-PWM303 to a yamaha natural sound receiver?
powered subs need a line level input so if the yamaha has this then yes you can
Oct 08, 2014 | Audio Players & Recorders
What model sub woofer can replace JVC SP-PW100?
open corel, at top click on about- click on activate and enter code
Sep 09, 2014 | JVC SP-PW100 Subwoofer
How do i get my JVC remote to get video to run in LP instead of SP when manually recording?
Usually you can change from SP to LP by pressing the record botton again. It works with some brands & models but not all. You will need to specify the JVC model # for exact instructions.
Oct 02, 2010 | JVC Televison & Video
We have JVC DVD Digital Cinema System Model TH-A9. We enjoy elethe set and have many hours per day playing with the DVD music as well as the movies. Suddenly, our powered sub-woofer Model SP-PWA9 fails to...
It sounds to me that the sub has blown a fuse. This could be caused by a faulty amp. Subwoofers are at the end of the day are just a mono amp. If the main amp in it shorts, it will blow the fuse.
A visual test might be all that is needed, plus your nose if it has fried the part!
Jun 11, 2017 | JVC TH-A9 System
My JVC SP-PWM508 no longer functions.
I am looking for the cable connecting the sub woofer and the main system(CD Player)
Mar 14, 2010 | JVC SP-PW100 Subwoofer
I HAVE JVC SURROUND SOUND SYSTEM MODEL SP-PWM 45,I HAVE LOST 8 PIN CONNETOR FROM MAIN AMP TO SUBWOOFER. WHERE CAN I PURCHASE THIS CONNECTOR THANKS
Thanks,
Dave
Sep 12, 2008 | Pioneer 1000 Watt 5.1 Surround Sound...
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
42 people viewed this question
 Grubhead
Grubhead
