Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
I have a Sony Wega LCD Projection 60wf655. When I turn it on, the red light turned green and blinks green 6 or 8 or 10 times or indefinitely. No picture but after a minute of being on the screen glows bluish. no channel or menu displayed. And the power light stays on green. It seems to try and turn on at first with a faint black and then dark grey flash but no picture. I tried shorting the thermal fuse and nothing. All the issues I've found are related to red flashing lights, mine doesn't turn red except when turned off. I have the service manual and have checked every capacitor and board they look good. What could be wrong? The bulb is new and seems fine too. A local shop said maybe a conversion chip? Don't know where that would be. Any help?
  • Garrett Fisher
    Garrett Fisher Apr 14, 2011
    I have tried shorting the thermal fuse wires and no change. I can see bright white light coming from the lens area so I know the bulbs working. But no picture and no red blinking errors.
    Problem Solver:
  • 10 Answers
This could be the "thermal fuse" which usualy is next to the light bulb. Part cost around $5.00. Please check your manual for directions depending on light and times blinking.
Posted on Apr 14, 2011
  • Garrett Fisher
    Garrett Fisher Apr 15, 2011
    I tried that as well as shorting the thermal fuse wires and no change. I R and Red the bulb to check it and it looks fine. The bulb lights and starts when powered on and I never get a red blinking light. After a minute the TV now glows bright white but no picture.
  • miguel_turci Apr 15, 2011
    The other reason could be the bulb light cover is not properly closed. Read your manual for what the color of light and times blinking means. If this does not work for you, call contact www.sony.com then go to ELECTRONICS then TVs then SUPPORT and look around for the area to chat with a tech (its free) complain about the BLUISH on your screen, could be something related to the ENGINE COLLOR, or COLLOR BLOCK, if your model is protected under the Class Action against Sony due deffective ENGINE COLOR you can probably qualify for a replacement with a brand new TV for a minimal price.
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
Jun 10, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The standby light blinks green like its about to turn on then keeps blinking red and nothing turns on
A very common problem in Grand WEGA, In short the solution is, The LAMP needs replacement. Replace the lame and it will work fine again.
Thanks.
Dec 04, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
My rear LCD projection Sony TV turns on for a couple of seconds then turns off and the status light starts blinking red
Well if you haven't replaced the lamp before, it's pretty muhc tie you should do it, but if you have, in this case the issue might be with your ballast
Jul 31, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Does not turn on.
The Six blinks mean that the thermal fuse needs to be changed.
Jul 07, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
KDF60-60wf655 lamp relacement problem
Make sure you have the lamp seated correctly
If you used a non sony lamp it may not be compatible
remove the lamp and look to see how the two connectors line up
they are the most important
Jan 27, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
141 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
