Question about AT&T 2.4 GHz 2255 Cordless Phone
CAN NOT GET DIAL TONE HANDSET SAYS OTHER HAND SET IN USE. i UNPLUGED REMOVED BATERIES AND STILL SAME RESPONSE. CAN YOU HELP? THANKS, MACK
No dial tone
Headset might need re pairing with the base. If this is anew set up you might need to change the compatibility dial.
Jan 23, 2013 | GN Netcom GN-6210 Consumer Headset
My phone dials too fast. The only way I can dial a number is by taking it off the hook and manually dialing after I hear the dial tone. If I use Caller ID, redial, directory, or putting in the number...
I had the same problem with a model 6325-4. Worked fine for the first week. Then, tone dial with redial, directory, etc was too fast for system to register the number.
Called Vtech support. After a 15 hold, 5 minute explanation and tech listening to a reproduction of problem over the phone, she asked that I perform a complete system reset (I called via my cell).
I unplugged power from base first, then removed battery from all hand sets. Powered down for ~3 minutes (with tech waiting on line the entire time).
I powered up base first and then reconnected all handsets. Selected a handset at random and performed the same dial from directory test I had done just before power down. The thing worked again. Call went through just fine. Tried several other selections in directory with same positive results. Now, if the system just stays stable and working.
Hope this helps..
Dec 19, 2010 | Vtech CS62192 Cordless Phone
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Handset display reads "searching". No dial tone. No response.
I am sure you have solved this problem by now. For others who might face the same problem...just unplug the batterry of the handset and plug it in..wow it works!!:))
Jan 20, 2009 | Uniden DECT 6.0 Cordless Telephone...
I cannot use my phones since Saturday. The phone message on hand
try to perform a soft reset.
Using:
menu/settings/ restore factory settings.
Dec 22, 2008 | Uniden Cordless Phone
GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Jul 19, 2008 | GE 25942GE2 Cordless Phone System
My landline phone does not work. I tested it outside on the company's jack and the phone works. I have 3 jacks in the house and it will not work on any of them, including the one I get the internet. The...
One of the phone handsets of the Panasonic KX-TG563 trio gives me static w/ dial tone and then shuts down or it gives me the message that "System is busy/Line in use" with no dial tone. If I get closer to the base unit it seems to work but w/ alot of static. The base unit phone works good and the other handset works ok too. The battery shows fully charged however, when I take the battery out to try a reset when I put it back in the battery indicator show very low. I tried switching batteries w/ the othe hand sets it doesn't help.
Thanks
Jun 07, 2008 | Lands Phones
Cordless phone keeps reading, "lift handset"
This would normally happen when the cordless handset was still in the charger stand. Are you saying it will still tell you to lift the handset after it's removed from the charger stand or base? I would not waste money buying a new battery as it is most likely not the problem but if you have more than one handset you should try swapping batteries. Removing and re-inserting the battery may reset the phone and clear up the problem as well.
Jul 05, 2007 | Coby CT-P8700 Phone (CTP8700)
AT&T 2.4 GHz 2255 Cordless Phone Logo
53 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
