Question about Cell Phones
Why would my outdoor telephone bell stop ringing. I tried changing the connecting wire, but still doesn't ring.
    Top Expert:
  • Cell Phones Master
  • 79,024 Answers
The ringer will malfunction if the electro-magnet that operates it is defective. Electrical devices that are outdoors are exposed to the elements and they do fail. I suggest you just replace it.
Posted on Apr 11, 2011
T7316E - Phones just installed. None of them ring.
You need to ensure that the main bell is programmed to ring, also that the extensions are also programmed to ring as well. Also check that the ringer is switched on, on the base of the telephones. Also ensure your handsets to not go over the ren value permitted. Make sure the service is on the correct day service and not night service. Check that the handsets ring internally and ensure they are registered with the system. Ensure that the connections and wiring are also correct,
Mar 15, 2013 | NorStar T7316E Telephone
When our neighbour's wireless bell is rung our wireless bell rings as well
Open up the back of your bell and the back of your button. There should be switches you can move. Just move them the same on the button and the bell. This will make it so yours doesn't ring when theirs does.
Sep 11, 2012 | Heath Zenith Designer Series...
What's your problem?bell doesn't ring when keys are left in ignition
the chime is burned out or the door jamb switch not sending a signal to the module wire break inside the boot that cover the wires between the door and body
Apr 05, 2012 | Cars & Trucks
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
Mar 03, 2010 | Computers & Internet
I require @ wiring connection for instalation of remote bell on @ barn? Phone is older model ITT
It's 2 wires. If you want to feel warm and fuzzy, try page 2 of the pdf http://wedophones.com/TheBellSystem/pdf/bsp/2500/502-523-402-8205.pdf
A bell in a 2554 set has a red and black wire. You can't connect them directly across the line, because it would short out the line. The network has a capacitor between A and K, so you wire the bell through those leads for bridged ringing.
Now, some bells have the capacitor already on the side...ITT mini ringers do not, but the 75-BA's do.
Carl
Nov 15, 2009 | Cortelco ITT/ 2554-VBA20MC Standard Wall...
MC 602 one of door bells rings intermitently.
I pulled the MC 602 from its wall case to examine wiring. Found a most unprofessional mess of wire connections. Cleaned up wiring and clipped the extra exposed shielding. Problem has not reoccurred, but time will tell it has sometimes been days between false rings.
Oct 13, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Intermittent Ring
Sounds like you are having a problem with the generated ring signal from the cable phone service. An old fashioned Ma-Bell ring signal is a pure 90v AC 30hz pulse. Your cable box needs to generate a simulated ring signal from a DC power supply. I have seen many examples of this fake ring signal not cooperating with specific phones. It's a long shot but your phones MAY have a setting for the phone line(s) (A/B) (Analog/Digital) etc... of you can find a setting dealing with the "CO line", "phone line" etc.. try changing it. I am surprised another phone in the loop will help the ring signal at all. I would think it could only weaken it. Try plugging your phone in question directly into the cable line instead of having the whole house connected. The ring signal may be trying to power too many devices or weakened by something connected to the network. Other than that, you are dealing with the ring signal generated by the equipment and I'm sure it's not adjustable.
Jun 26, 2007 | GE 21028GE3 Cordless Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
