Question about Dometic Rooftop RV Air Conditioner
Our RV AC runs and the air feels cool, not cold, but our RV feels hot even though it's running. What could the problem be?
  • 413 Answers
Low refrigerant or a stopped up condenser coil on the roof.
Posted on Apr 11, 2011
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
Air not cold enough to cool house
Make sure the outside fan is running. Also check the high side pressure, I assume the 70# is the low side pressure, so you can tell what the compressor is doing. If the fan and compressor are both working, make sure there is good airflow through outdoor coil and check that it is clean. Let me know what you find.
May 17, 2010 | Goodman CLJ24AR32 Air Conditioner
AC is off but compressor cycles periodically
most likely your compressor contact is stuck closed, and will need to be replaced. if the fan also runs when the compressor comes on you may have a short between the t-stat and unit. hope this helps.
Jun 14, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm Model 630515
check freeze sensor should be plugged into coil then air box cannot mix intake and cold air if all ok low on Freon cannot refill
Oct 04, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
402 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
