Question about Vacuums
Jc penny model 1710 sewing machine, the stitching isnt tight
  • 2,510 Answers
You do not say if it is the top stitches or the bottom stitches for the bottom tension, check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
For the top stitch, tighten up on the tension adjustment on the front of the machine which looks something like this:-
jc penny model 1710 sewing - images?q=tbn:and9gctmqnuzdetdofn3rmptgx4d6h3wsbbewgyursvcfmpbxpewspjy
Posted on Apr 11, 2011
I have an error reading e1 but the bobbin and thread are fine
You need to hold the thread tightly when you do your first 5 or 6 stitches. The pull out card on the machine will tell you exactly what the E1 error mean
Jan 02, 2015 | Singer Futura CE-250
The thread is curling when it comes out of the thread guide stitches are tight bobbin thread is good
Your needle seems to be out of adjustment. Try moving the needle up a little then see what happens. GOOD LUCK FRIEND.
Nov 22, 2014 | Kenmore 19233 Computerized Sewing Machine
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
The Tesco EJ09 sewing machine upper thread is too tight on tension how do we alter this, we have adjusted as per manual
Is it the stitching that is too tight or the thread? Pull the top thread all the way out (un-thread the machine) and start over.
Aug 31, 2011 | Vacuums
Loose stitches tention loose long stitches, what should the setting be for straight stitches? for a 7318 model janome
Thread tension is more dependent on what you are sewing than machine model. Upper should almost always be tighter than lower, and the thread should pull up into the fabric being sewn.
Aug 18, 2011 | Vacuums
Looking for a signature sewing machine model # UHT J276A
I have one, I bought it for the cabinet for another machine. There is no manual but it does sew, I tested it. It looks like it has been very used. I could not test the fancy stitches without a manual.
Oct 27, 2010 | Vacuums
Vacuums Logo
268 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
