Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
The display turns blue and shows this error message : error 0x06217c2b. Beneath it says 1569:pen_id.c What's the problem? Earlier it has told us that there's something wrong with the black ink cartridge - that problem seemed to disappear as we shifted the cartridge to a new one. But it only worked for about ten prints... now we've got this new problem.
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Posted on Jun 16, 2009
pastorm
  • 98 Answers
SOURCE: pen failure message from utility
HP tech support suggests cleaning the ink cartridge contacts and the contacts inside the printer for the cartridges. If this does not clear the problem, try replacing both cartridges (color and b/w) with new ones.
Posted on Jul 27, 2007
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
CompuFirm
  • 89 Answers
SOURCE: Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
Posted on May 27, 2009
What should I do when the Display says Service call 132:Error
After turning ON the
power or when cover
is closed, the sensor
detects that the unit is
missing.
1) Is an Error message displayed?
2) Is the LED head properly
mounted?
3) Does the Error take place
again?
Confirm that the lever is in
position.
Replace the toner feed unit.
Replace the ID units.
May 27, 2014 | OKI C5100n Laser Printer
Message counter displays more than I have saved
I think you might be confusing the counter that keeps rack of caller ID information, and the counter that tracks messages stored in the answering machine - two different things, different purposes.
The answering machine part displays "new messages", but can store "old messages". For the caller ID part, look for a button on the handset that says "caller ID" - hit that, and then there will be a scroll up/down pair of buttons - you can look through your received caller IDs. Their may be a delete button on the phone (It's not clear what model you have), which will allow deleting that caller ID out of memory, but if not, having viewed the numbers, your "20" on the message counter should reduce.
Apr 03, 2014 | Uniden DECT 6.0 Cordless Telephone...
Iam unable to save data on pendrive
Pen drive? A USB drive? Have you formatted the drive? Do you have Admin. rights? Remove the USB drive , reboot the computer, insert the usb device, does the computer ID the device and apply a driver? Do you get a popup? Does it show in Computer? What are you trying to copy to the drive?
Jan 17, 2013 | Acer Extensa 4620 Notebook
It was showed an error code (D1.071B) by HP CM8050 displaying.
questions already been answered http://www.fixya.com/support/t8700781-code_d1_071b
May 09, 2011 | Computers & Internet
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
Dell 8400
hello
If the blue screen shows MEMORY DUMPING message then your RAM is either gone or dying.
If it is showing some other message then please mention the message or error it is displaying.
Thank you
Aug 16, 2009 | Computers & Internet
8gb pny pendrive not working
Try to connect it to another usb . If it still does not see it do check disk with fix errors. I had such a problem many times and usually check disk helps.
Apr 18, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Delstar DS801 MP4 player
take it back to were you got it as you have a internal disk problem and disk means hard drive in laymans terms
Feb 02, 2008 | Delstar DS 917 Digital Media Player
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Sep 26, 2007 | Computers & Internet
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
106 people viewed this question
Seeker5211
Seeker5211
