Question about Troy Garden
I need the clearance setting for the magneto on a 12AV5560711 mower
  • Troy Master
  • 7,482 Answers
Use a paper match book cover...or .20
Posted on Apr 11, 2011
Whats the air gap suppose to be set at
Easy way to set that is to put a piece of electrical tape over the magnet on the fly wheel and rotate the fly wheel till it is under the magneto and then loosen the magneto bolts till you can slide the magneto up against the tape, Tighten the bolts, rotate the flywheel out of position and remove the tape. Rotate the fly wheel by hand to check for free clearance all the way around.
Apr 29, 2016 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Whats the air gap on a craftsman 247.290000
.012 or Easy way to set that is to put a piece of electrical tape over the magnet on the fly wheel and rotate the fly wheel till it is under the magneto and then loosen the magneto bolts till you can slide the magneto up against the tape, Tighten the bolts, rotate the flywheel out of position and remove the tape. Rotate the fly wheel by hand to check for free clearance all the way around.
Apr 29, 2016 | Craftsman Garden
What is the clearance of the magneto to the flywheelon a L111 20 hp engine
Most air gaps are set at .010-.012 or basically a standard business card thickness. For actual factory will need the engine numbers.
Jun 14, 2015 | Garden
Why does my Briggs and Stratton lawn mower engine crank, back fire, and not start
sounds like you need valves adjusted. either google your engine model number and "valve adjustment", or let me know what the # is and i can try to find a link.
Jun 23, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
What should the clearance be betwwen mag and fly wheel toro
The gap should be about .010 (Ten Thousandths of an inch), but truthfully, the way I set it is to loosen the coil bolts and place a shiny business card in between the coil and flywheel. Tighten the coil up snug against the business card and then remove it. This should set the gap close enough to the correct setting for you; done. Hope this helps and best of luck to you.
James
Nov 11, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Briggs engine 143-586244 on a old snow blower will not start. Evan when I use starting fluid, choke it or open very little. It has not ran for about 30 years. I drained the old gas back then. Now I...
Do you have spark at the plug.if in storage that long its possible the coil and magneto clearances are corroded. I get alot of mowers in that have been stored outside over winter that are rusty and corroded.
Aug 29, 2011 | Garden
Id like to know if you can test your magneto without a multi circuit tester ? if i am getting spark, is my magneto still good? how do i read the numbers to know what year i in fact have ?
If you are getting a strong, blue, spark on a known, good spark plug, then the magneto is good. If the spark is weak (barely visible), then it is most likely the clearance or rust build up.
The easiest thing to do is check for rust on the surface of the magneto and the surface of the pick-up coil. Emery cloth is good for removing rust on both. Then check for the clearance between the pick-up coil and the magneto. The closer to the magneto, the more powerful the spark (but rotate the magneto to ensure it never touches). When you loosen the screws on the pickup coil to adjust, make sure you have a business card to place between the surfaces to keep them from touching. The strong magnet in the magneto will pull the pickup coil to itself. Tighten the screws and remove the business card. Check for clearance as you rotate the magneto.
The only thing that can go bad in a magneto situation is the pickup coil. So, if you're getting a spark, it most likely is not the pickup coil because it will either produce a spark or won't.
May 31, 2011 | Suzuki RM 250 Motorcycles
Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Apr 07, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It wont spark at all. No fire. Just put a new spark plug so that's not the issue. This lawnmower is only 1.5 years old. Thanks
Could be magneto bad, wire from magneto bad, ground on magneto bad, or the clearance between the flywheel and the magneto is rusted up if it was outside. Clean flywheel with sandpaper and set magneto gap using a match book flap.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Not enough spak-new magneto-plug-all gaps ok
Be sure you have set the magneto at the correct clearance. Make darn sure that the elements for an engine to start and run good are fuel, good air , and a good spark..That clearance by the way should be .010 to .012/ Good luck. don
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
91 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
