Question about Dell Latitude D600 Notebook
Won't start Ran extended test, error messages, Error Code 0F00:1A44 Msg blocked 59219451: uncorrectable data or media is write portected also 82951142 82951645
    Genius:
  • 2,028 Answers
Use your recovery or operating system disc to run a repair, type in chkdsk /f /r. This should take care of it, however, this could also be a failed hard drive. If the repair doesn't do it. Then reformat the drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. When formatting, do a full NTFS format, if the drive will not format, then it's done.
Posted on Aug 08, 2008
    Sergeant:
  • 395 Answers
Boot using Recovery CD and run chkdsk /R C: to fix errors then reboot.
You may have to install a 2nd copy of XP which will trash the first copy but at least leave your data files intact.
IDE disk read test block failure
try to run with chkdsk command and if it is fail kindly replace the disk.
Nov 14, 2011 | Dell Dimension 4600 PC Desktop
I WENT FOR EXTENDED TESTING FOR MY DELL VOSTRO SYSTEM.. AND RECEIVEED ERROR CODE: 0F00:0244 MSG:DISK_0 BLOCK 34410367 CANT READ, REPLACE DISK OR REMOVE WHITE PROTECTION.. WHAT DOES THIS MEAN??
Uncorrectable data error code or media is write protected which mean the test found a big problem have a computer repair shop look at it.
Jun 16, 2010 | Dell Vostro A860 Notebook
Dell Laptop Vista repair stuck! My Dell Vostro 1500 does not start. It is Vista Home. So, I am trying to repair it with the installation disk. However, the installation stuck after the "Windows is loading...
leerobin
It does look like you may have a problem with the hard drive on the computer.
In regards to recovering your data if you have access to another computer you can connect the hard drive to it to see if the data is recoverable. Note since you ran the system recovery it may have over written your data. If this is the case then you might check with your local computer store to see if they have a hard drive data recovery program. As long as there is not a physical problem with the drive they may be able to recover the formatted data.
After that I would look at the top of the drive to see who the manufacture of the drive is then download there diag and repair tool for the hard drive. While you have the drive on the computer run a repair scan on the drive. If you just have some bad sectors then the diag program will zero them out and repair the drive. If the drive is indeed bad the program will tell you this as well.
If the drive is bad and your computer is still in warranty then you should be able to get Dell to send you a replacement hard drive. If you are not sure if you are still in warranty let me know the service tag of your computer and I can look it up for you. Also note you will want to have Dell send you your recovery CD if you do not already have it.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 20, 2010 | Computers & Internet
My OS freeze's as soon as i input my password
Hi there.
Sorry but i have to inform you that your hard drive is failing, the error messages that you are getting relate to this fact and is related to the hard drive having unrecoverable bad sectors or immanent hard drive failure.
There is no way you can recover the drive!!
Your only option now would be to buy a new drive for the computer or if the machine is still under warranty take advantage of that and send it in for repair, you will no doubt have to purchase a windows installation disk too.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Dimension 9200 PC Desktop
Error code 0244
Hi there.
Error Code 0F00:0244
"Msg Block 5*****4: Uncorrectable data error code or media is write protected"
Sorry to say the hard drive has failed or is corrupt with bad sectors, with these Dell drives there is no way of fixing them.
There maybe a possibility that you can recover your data if it still spins up and you add it to another computer as a slave device.
May 20, 2009 | Dell Computers & Internet
Can't boot windows xp
it sounds like the easiest solution would to either run the repair sequence from a windows xp disk (may not be a perminant fix) if that doesent work just use the xp disk to format the drive and install a new operating system
May 10, 2009 | Microsoft Windows XP Home Edition
Laptop PC running XP Home Edition will not boot, error code 0F001A40 Msg: Block 43982261 Uncorrectable data error or media is write protected
It sounds like you have a corrupted hard drive you can try to restore to last known good configuration by pressing F8 when you boot up. If that doesn't work find your restore disk and select repair windows first. before installing new(all date will be lost) mysleuth
May 06, 2009 | Computers & Internet
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Dec 30, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Dell Latitude D600 Notebook Logo
170 people viewed this question
Alun Cox
