Question about Ryobi Cultivator
I need to change the gas out. How do I empty the gas tank? I don't know the oil to gas ratio, what is it? I'm not sure how to start it. How do I do that? someone gave me this cultivator but it has no booklet. Thank you for your help...Sharon
wadembly
  • 489 Answers
SOURCE: fuel lines on my cultivator corroded. I do not
ok you have two fuel lines coming in from tank the one that has the fuel filter atached inside should go to the top & the other is just the return line try that & let me know if it helps wade at wadembly@aol.com
Posted on Jun 06, 2009
rustysheriff
  • 344 Answers
SOURCE: gas lines on ryobi cultivator
Exploded view:-
http://www.outdoordistributors.com/pdf/Ryobi/RYOBI-410.pdf
Did you replace the gasket (item 15 on the linked document) when replacing tank and lines, if you didn't and the old one has been torn it could be sucking in air, also the 4 carb mount screws need to be of equal tightness
Posted on Apr 23, 2010
  • 277 Answers
SOURCE: fuel oil mixture ratio
I have a 410R still looks like new.
it has on it gas & oil = 40. to 1 for mixture.
mine never gets used so it is still new.
Posted on Jun 23, 2010
SOURCE: what is the correct gasoline/ oil mix ratio for
I use 1 oil to 20 gas
Posted on Aug 13, 2011
  • 21 Answers
SOURCE: I have the Bolens BL410 gas cultivator. It won't start. I have changed the gas and the spark plug but it won't start. I don't know what else to try
Spray starter fluid in the air filter. This should work.
Posted on Apr 09, 2012
I have a 2008 KTM 105 SX and I don't know how much
Use 50:1 ratio or 2% oil in the mixture.
That means 20ml oil for every 1000ml (1lit) of gas.
Oct 22, 2012 | Motorcycles
Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 18, 2012 | Echo Garden
I changed the oil lines and now I need to prime the pump to get oil into the carbeuretor.
There are a couple of ways to approach this. One is to remove the spark plug and turn the engine over several times to purge the air out of the lines. Some people opt to use a little premix, where you mix about a 20 to 1 ratio of two stroke oil and gas. You only need a little, like 8 ounces max, to place in the empty gas tank. You fire the engine up and run it a few minutes on the premix, and then top off the fuel tank with fresh fuel. The premix protects the engine while the oil line purges of air.
Oct 05, 2011 | 2005 Tomos Sprint
I have a 340 Air Injection Chainsaw. We made sure it has gas/oil and chain saw oil. We get it started but it won't stay on? What are we doing wrong.
If it has an air filter make sure it is clean, also check the gas filter in the gas tank,
sometimes it will get gummed up and will pass very little fuel, it can be pulled out
by making a hook on the end of any wired coat hanger or stiff wire, once you pull,
it out remove the fuel filter , put the fuel line back in, make sure it is submerged
in the fuel, if it keeps running, just replace the fuel filter, the gas tank will have
two lines going to it, normally only one has a filter, also make sure the lines are
intact and don't have any cracks or breaks. make sure your gas to oil ratio is
correct. most chains will have it written on the chainsaw, or check your user's
manual. 40:1 ratio on older models , on newer models 50:1 good luck!
Jul 02, 2011 | Husqvarna Garden
I bought a honda 125 to a friend it runs good but sometimes the spark plug has full of black residue after running and when the time comes it doesnt start, the black smoke when cranking seems to be an...
i'm not sure on this bike,,,but if your adding oil to the gas,,i'm assuming it's a 2 cycle,,,, there for,,,,if your getting a heavy build-up of oil on the plug,,,,,, make sure you are using exactely the correct ratio of oil to gas,,,,, read your manual,,it will say the correct ratio,,,,make sure it is 2 cycle,,,,, if it is a 4 cycle,,,what is this alR// ,, you wrote down ?????? if it is a 4 cycle,,,,empty your gas tank,,,,,change your plug,,,,,add nothing to your new gas,,,,,, it should run fine,,,,again,,, i'm confused about this alR// stuff,,,,,, feel free to contact me with any other problems,,,,, i'm sure i can help you JOEL
Aug 19, 2010 | 2005 Honda NF 100 Wave
I inherited a Sears 647G chainsaw, but no manual. It has separate tanks for the oil and gas. Do I put a mixture of oil and gas in the gas tank? The oil tank I think is just to oil the chain. Or does it mix...
I'm sure the separate oil tank is for the chain... you'll need to mix the gas with 2 cycle oil... typical ratio is 40:1 to 50:1...
Manuals are going to be real scarce... you may want to check with a local small engine repair shop to see if you can copy something they may have...
May 16, 2010 | Garden
Gas gage read full when empty and sometimes emty
You have a bad fuel level sensor.The fuel tank needs to come out and the sensor replaced.You don`t have to replace the pump assembly.You can get the level sensor separate.I`m not sure if the parts stores have it but I know the dealerships do.Hope this helps.Good luck.
Mar 16, 2010 | 2004 Pontiac Montana
In the control box of an evinrude 115 vro v4 is an alarm why does it go off every 15-20 min when the motor running
The warning horn on a V.R.O. system ( variable ratio oilier) warns you of three problems. (1) LOW OIL. means the remote oil tank in the boat is near empty or empty(2) NO OIL. means there is no oil getting to the V.R.O. .problem is, clogged line or the diaphragm in the V.R.O is blown.(3) OVERHEAT. means the engine is overheating. The V.R.O is you lift and pressure pump for fuel and oil. plus it mixes the oil and gas to proper ratio. Three warning, three senders. LOW OIL sender is in the remote oil tank in your boat. NO OIL sender is in the V.R.O.. and the OVERHEAT sender is on one or both cylinder heads of a the engine depending on the year model
Sep 02, 2009 | Boating
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Aug 28, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite broom help I put way too much oil in now it's smoking!
i agree finding the ratio is no as easy as it should be. yes. drain the tank. don't use the old gas somewhere else. use fresh gas & mix ratio in separate gas can or container. use a bit of ether/starting fluid into the air-filter inlet opening help fire it up. a new plug is fairly low cost and easy and that might also be needed after the oil bath and 3 years.
Nov 03, 2008 | Garden
Ryobi Cultivator Logo
14 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
