Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
2 problems one a reading of general fault the
2 problems one a reading of general fault the other is even though I increase the ORP I can not raise my chlorine levels it hovers around .5
  • 310 Answers
How are you increasing the orp if not with chlorine?
ORP is not a direct chlorine reading and can be misread for a number of reasons, if your alkalinity, ph, cyanuric acid, or TDS levels are out of control, the ORP reading on any controller will be mute. These controllers manage ph and chlorine only (typically), but all the other chemicals and water treatment rules still need to be handles by the user.
It is also possible that your orp probe has gone bad. The most important thing to have dialed in is the pH, otherwise you will never get a correct ORP reading, as they are only accurate when in between 7.2-7.8 pH value.
Also, if you cant raise the pH above .5 no matter how much chlorine you add, you might just have old contaminated water, if the TDS and the CYA are extremely high, you will see this scenario.
Posted on Apr 11, 2011
What should the psi compression be thanks.
It can vary between make and model of car. However, a general rule of thumb is that 135+ average is okay. Less than 85psi is pointing at something seriously amiss in the engine.
It can vary - some cars may have 125psi as 'average' compression.
Don't expect each cylinder to give the same compression reading as there will be a fluctuation. Another general rule of thumb is that there shouldn't be more than 10% variation between the readings. That is, if cylinder No1 is 135 psi, cylinder No2 shouldn't be less than '125 ish'.
If you suspect you may have compression issues, it's quite easy to do a bit of fault finding. Warm the engine first so that the pistons are expanded in the cylinders. Then do a dry compression (normal) test.
Here's some examples of compression tests on a 4 cylinder engine:
130 127 129 127
All compression readings are within 10% of each other. Fine.
Example 2:
95 95 129 127
Here, a low compression reading on cylinder 1 and 2 suggests a problem. It may be due to a faulty head gasket/cylinder head allowing compressed gases to be transferred via the defective head gasket from one cylinder to another.
Example 3:
130 80 129 127
Cylinder No2 has a problem. It's compression is way down. The other three cylinders are fine. So .. what is the cause of the low compression on cylinder 2? It could be a broken ring/cracked piston or a burnt exhaust valve.
This is where you do a second compression test - called the 'wet' test.
Squirt some light engine oil into each cylinder. Aim for the cylinder walls so that the oil can find its way down the walls and around the piston rings. Place a rag over each spark plug hole and spin the engine to expel excess oil.
The oil that you have sprayed into each cylinder will form a 'seal' around the piston ring. Do another compression test and note down the readings. Here's example 3 again:
Example 3:
130 80 129 127
.. with the low compression on cylinder 2.
If after carrying out the 'wet' compression test you have a reading along the lines of
130 100 129 127
suggests that the bore/piston rings in cylinder 2 are at fault. The compression has increased on No2 cylinder because of the oil forming a seal around the rings.
If there is no increase in psi on the wet test i.e
130 80 129 127
This suggests a burnt exhaust valve.
May 17, 2016 | Cars & Trucks
The engine light just came on ....what could it be?
run the fault codes first to determine the failure
engine lights report on engine and transmission
check coolant levels , sump oil levels, over heating, transmission oil levels for obvious problems and the codes will report on sensors and the like
Feb 10, 2016 | 2008 Toyota Matrix
1997. Why has it started sputtering?
The oil is a sign of a problem and the plug may be fouling. A compression test is a start. Generally a squirt of oil will increase compression readings in the bad cylinder during a compression test if an oil ring is at fault. If there is no change with the squirt of oil, it is a valve stem seal or a head gasket problem.
Jul 13, 2015 | Mercury Grand Marquis Cars & Trucks
Left front Tire Pressure Low Warning , Tire Pressure Good Scroll Though Menu and Indication on Dash reads 1 psi is it the wheel sensor or does the sysytem have a nother fault or require recalibrated
Have you rotated tire positions? Anyway, if all tires seem to be physically stable, give it a few more runs and another mileage. The 1 psi reading should increase and improve significantly. If not, it is best to have your tires recalibrated, from there you can easily determine if that sensor is at fault or not.
Dec 27, 2010 | 2007 Chevrolet Tahoe
My washing machine fills very slowly even though there is plenty of water supply. Sometimes the water only dribbles in. The worse time is on nthe rinse 2 cycle. Now it stops when the machine gets to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 01, 2010 | Fisher and Paykel (IWL12)
DVD CD ROM Problem
CD/DVD Drive Missing In My Computer
1. Go to Control Panel > System > "Click Hardware Tab" > Device Manager > IDE ATA / ATAPI Controllers > Right Click then uninstall
2. Reboot
3. If the problem is still their you will need to remove the upper and lower registry keys. You can do this by following this Microsoft Knowledge base article. http://support.microsoft.com/kb/314060
Sep 21, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
The screen is too dark to read anything though the power comes on. i tried to increase the brightness but did not work NEED HELP!!!
Sounds like your backlight or inverter is on its way out. You can pick one up on ebay.  Google how to check backlight/inverter issues with your model.
May 02, 2009 | Computers & Internet
My check engin light is on but it's running fine
An engine light may come on if one or more of your cars sensors finds a problem. Not all problems are big and not all problems effect the driving performance of your car. Bu even though it hasn't effected your driving in most cases it eventually will. For instance, i have a car with a turbo, my engine light came on because for a brief second my turbo produced more "pressure" than normal. Since it wasn't effecting the way the car performed i left it. A year later my turbo broke because those brief seconds of increased pressure happened once a day for a year and eventually damaged the turbine. So even though your car runs fine, you may want to bring it to a service station just to get the code read. unfortunately a code reading can cost anywhere from $25-$100 depending on where you go, but it could save you a lot more money in the long run.
Dec 01, 2008 | 1995 Ford Contour
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
149 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
