Question about HP Deskjet D2660 All-In-One InkJet Color Printer
Works only when pc has been turned off and on again
  • toshaughness Apr 19, 2011
    all that was needed was a new black ink cartridge. money back? tos
  • 4,281 Answers
For that you need to uninstall old driver then reinstall printer driver will fix this issue. Click here Click on above link select os and download driver then install. Scan computer with updated antivirus. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Apr 11, 2011
Will not start
Have you tried turning ON PC, turn it over and remove battery. Turn PC over again and turn on. Turn over again and put battery back in. Turn on again and see if it works.
Dec 01, 2012 | Computers & Internet
Tip
If everything is OK But no Display!
if you turn on your computer and everything looks good and work but there is no display, it means your motherboard got a software problem.<br />there is two way to reset the Bios of motherboard and solve the problem.<br /><span><br />so do these steps:<br />1- evolve the battery.<br />2- install it again but upside down.<br />3- turn on the PC.<br />4- wait 15 seconds.<br />5- turn the PC off.<br />6- install the battery correctly and enjoy.<br />if it doesn't work do these:<br /><br /><span>1- remove all the cables of your PC.<br />2- open the PC Case.<br />3- remove the Battery From yur Motherboard.<br />4- wait 15 minutes.<br />5- assemble the battery again and turn on your PC.</span></span><br />
on Jan 17, 2011 | Computers & Internet
Power went out last week. Can't print. The jobs
OK try this Remove Power Cord from Printer, remove USB cable from PC. Reboot PC. Wait 10 mins, then connect, the Power again to printer. Turn OFF PC. While OFF plug in the USB cable TO any other USB other than the one used before. Turn PC ON. After a bit you should hopefully have a working printer. If that doesn't work, Unplug USB, reboot & then using your DVD re-install it all again.
Feb 15, 2010 | HP Photosmart C7280 Printer
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
I HAVE AN OLD AMD DURON WITH A MOBO ATTACHED OF COURSE BUT THE PROBLEM BEING IS IT POSTED WHEN I FIRST SET IT UP NOW I WENT TO TURN IT BACK ON AND IT WONT EVEN POST AT ALL ITS ALL POWERING UP BUT NOTHING...
hello sir, try the following.
  1. turn off the pc and remove the side cover, locate the memory module, and reseat it (remove and put it back). power on the pc. Still not working?
  2. off again, remove the memory modules again and clean its gold plated contacts by using an eraser (the pencil eraser) then put it back again. power on. still not working? do 1 and 2 several times. (make sure that the memory modules are good)
  3. If several times has not worked, try to isolate the problem by removing all the connectors except. 20/24 pin power connector, the vga cable, front panel leds and switch. do 1 and 2 again.
  4. still not working? check your motherboard connections and review your work?
  5. is you pc 220 v plugged on 110v?
  6. Reassemble the board again.
Sep 14, 2009 | AMD64 mobo1 Motherboard
No signal display
you change the RAM, accordingly RAM did not work properly, when you start the computer RAM did not work and make some power again your system on, but when your windows come then you RAM fettal, and you system is off.
ok
Jun 08, 2009 | Acer Aspire M1641-U1521A PC Desktop
TO noggin
remove all pwoer connector from motherboard and short green and black wire in supply shocket.If supply is run then it is the problem of motherboard.
Feb 28, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
HP Deskjet D2660 All-In-One InkJet Color Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
