I want to move my itunes off my computer on to a disc ... I bought maxell CD-R music discs but I'm not able to burn the disc. The itune program keeps saying it can't read the disc
    Genius:
  • Computers & ... Master
  • 1,056 Answers
Couple of things.
First, turn the disk over and try it. It can only burn data on the data side.
Next, are you sure you have a CD burner in the computer? The way to check it go to computer propreties, device manager, and look for the CD Drive. Make sure it says R/W
Third, you might have a bad disk, try a different one.
What are you using for a burner program?
Posted on Aug 07, 2008
How do I download my purchased music from my iTunes account to a disc from my computer
Here's some instructions with visuals to aid you with this (assuming you're using iTunes 10 and above):
How to Burn CD with iTunes
Hope this helps!
Sep 16, 2014 | Computers & Internet
Tip
How to convert M4P music to MP3
The music and audiobook files you purchased from online stores are protected by DRM. But most mobile players doesn't support DRM format. However you can burn the protected music files to CD-R/RW disc to make an audio CD, then use CD ripper softwares to rip the audio cd track back to MP3, WAV, WMA etc.
There are two ways to convert M4P music to MP3. One way is to use itunes for sophisticated computer user, another way is to use third party program for beginner, which is much easier.Following the steps , then get your job one easily.
Part one: Using itunes to converting M4p music
Step 1: Run iTunes and set burner options firstly. You can choose
Edit>Preferences>Advanced>Burning menu and then select your CD burner.
Note: If you don't have a physical burner, you may use a virtual burner program, NoteBurner. Go to http://www.noteburner.com to download the program. After you install it, you can choose NoteBurner Virtual CD-RW as what you do in the first step.
Step 2: Create a new playlist in iTunes and add all m4p files you want to convert to this new list.
Note: If you use NoteBurner, you need to select the output format in NoteBurner. After you click Settings button, you can set the output as MP3, WAV and WMA.
Step 3: Click Burn Disc button in iTunes to starting the burning. If you use NoteBurner, this is the final step since the program can rip back the burned music automatically. The output folder will be open automatically after all music finishes encoding.
Note: If you burn the m4p files on real CD, you need to rip the music back in iTunes. Open iTunes Edit>Preferences>Advanced menu and click small Importing tab inside the Advanced tab to choose "WAV encoder" or "AIFF Encoder" in the "Import Using" dropdown. In the left-hand panel under "Devices", select the CD that you burned
Step 4: In the main window opposite, deselect any CD track(s) you do not want to convert. Right-click or control-click over them, and choose the "convert to AIFF" or "convert to WAV" option.
Step 5: After the conversion, you may find the converted file at C:Documents and SettingsAdministratorMy DocumentsMy MusiciTunesiTunes Music
Part two: Using third party program to convert M4p music
Comparing to the previous method, the following is more simple and easier, you can finish the job with just several clicks.
Step 1: Free download M4P Converter, install and run it.
Step 2: Clicking "Add" or directly drag-drop protected M4P files. Batch M4P to MP3 conversion supported.
Step 3: In the "Setting" button, choose MP3 format (*.mp3), you can also custom the music.
Step 4: Click the "Start" button to start converting M4P to MP3. After successful converting M4P to MP3, the result shall be stored on the "Output path" folder. Then you can use them for playing without any limitation.
on Oct 28, 2010 | Computers & Internet
Itunes wont open
A corrupt iTunes library prevents the iTunes program from opening and prevents Apple device synchronization. According to Apple, the iTunes library must be rebuilt, which resets the library and removes the current content in the media manager. Back up your media prior to recreating the library, as the recreating process erases all content and your Apple device will synchronize with the blank, recreated library and erase the device's information.
Insert the DVD-RW disc into the computer's DVD-RW drive, and open iTunes. Click "File," "Library" and "Backup to Disc." Select the iTunes library and playlist backup and click "Next." Eject the disc after the backup completes, and close out of iTunes. Move "iTunes Music Library.xml" from your iTunes folder to the desktop. Right-click "iTunes Library" and click "Delete." Launch iTunes and click "File," "Library" and "Import Playlist." Locate and double-click the iTunes Music Library.xml file. Insert the burned disc into the DVD-RW drive and click "Restore." or
Fix iTunes if It Won't Open on Your Computer b> You've clicked and clicked and clicked some more, but iTunes just refuses to launch. A non responsive program is frustrating to any computer user, but especially if all you want to do is listen to some music or download a new album. If iTunes isn't opening, there are many possible causes for this error. None of these fixes will affect your current music collection. Though you may need to tweak or reinstall some software, your MP3s will stay right where they are.
Confirm that your Apple device is connected securely to your computer. If you are not trying to access iTunes via an Apple device, or if your device is connected correctly, continue to step two. Configure your firewall to allow iTunes to connect to the Internet. Many firewalls block software programs' ability to get online as a security precaution. This is because some spyware and malware is designed to transmit personal data from your computer. Making iTunes a trusted program within your firewall software is necessary for it to function properly. Create a new iTunes library file. An unstable or corrupted library file can cause iTunes to suddenly quit or not open at all. Recreating a library file is a lengthy process that depends heavily on the operating system you are using. See the iTunes Support page under. http://support.apple.com/kb/HT1451 Reinstall iTunes on your computer. If no other troubleshooting steps are successful, then the fastest way to solve the problem is to start from scratch. Hope this helps.
b>
Dec 26, 2012 | Gateway MX Computers & Internet
Cannot burn audio cd with iTunes
Maybe iTunes don't want your burning their music. I'm not sure cuz I don't use Itunes, but if it works on others that sounds like it might be the problem.
Here I found the below on Apple's site.
Symptoms Find out what to do if you can't burn an audio CD using iTunes for Windows. Sometimes an audio disc may not burn as expected. Here are some things to check.
Resolution Update iTunes Download and install the latest version of iTunes for Windows.
Songs not authorized iTunes will stop burning a disc if one or more of the songs in a playlist were purchased from the iTunes Store but are not authorized to play on this computer. This message appears:
"Some of the files can not be burned to an audio CD. Do you still want to burn the remainder of this playlist? For more information on why some files can not be burned, click below".
There's more so click the link below and see why you can't burn your cd.
http://support.apple.com/kb/TS1436
May 09, 2012 | Dell Optiplex 755 Desktop Intel Celeron...
I have a super multi GP10 and I don't know how to burn music from my iTunes with it. I can't install the software.
open Itunes in the top left hand corner select file from thdrop down list you will see Library click to open then you should see back up to disk then more options back up entire library to disk
this might be because you have not selected the option to burn an audio cd or your burning software does not support audio burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
May 21, 2011 | LG GP08NU20 DVD±RW Burner
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
How do I transfer my itunes to another computer?
Cucusoft iTunes to iTunes Transfer is an easy to use iTunes utility designed to help you backup/recover/transfer your whole iTunes library and media files. It's a simple way to keep your iTunes in sync everywhere. You can use "iTunes to iTunes Transfer" to backup your own iTunes library or synchronize multiple iTunes on different computers. The backed up library file is pretty easy to transfer to other iTunes, and it's easy to manage. So with this iTunes Transfer software, you can manage your iPod/iPhone/... on different PCs
Transfer photos, music, videos from iPhone iPad iPod to computer or Mac by this software:
http://www.mustsoftware.com/Cucusoft-iPad-iPhone-iPod-to-Computer-Transfer-guide.html
For iphone/ipod/ipad to Mac transfer
Jul 27, 2010 | Apple iTunes
Burning music from itunes
this is just itunes its perfectly normal
Jul 21, 2009 | Apple iTunes
Re-writable Maxell CD-RW - 700mb/80mins
hw could i put burn songs to a maxell cd r
it is not re writable
Mar 08, 2008 | Maxell CD-R 80 Minute 700MB Media...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
