Question about Lexmark X2600 InkJet Printer
My lexmark printer is doing everything it's supossed to, but it's NOT printing. There isn't even any paper jammed. what could the problem possibly be?
  • Official Brand Answer
  • 3,344 Answers
Try to disconnect your printer from your computer. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reconnect to your computer. Doing this usually fixes minor communication issues. If that doesn't help, try to check and make sure the print spooler service is running on your computer. Refer to this article: How to Restart or Reset the Print Spooler in Windows.
Posted on May 03, 2011
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
The Lexmark x342n all in one printer gives the error code 200.20 i took out the paper jam and tried to print again but it still gives the same fault i also can the drum and tried again but it only...
General tip: If the paper tears when you pull a jam out of the printer, spread the paper out and make sure you have all of the pieces. A small shred left inside can cause another jam.
"I also can the drum" - does this mean you discarded the printer cartridge? I've never seen a cartridge cause a jam. Usually an accordion-fold jam in this area is the result of the fuser rollers not turning or a torn fuser sleeve. A jam without an accordion fold indicates that the paper did not make it into the toner deposition area soon enough - this could be a problem with the pickup roller or the next set of rollers. Worn or dirty rollers can work intermittently before they quit completely.
Also, check the paper detection flag to make sure it isn't hanging up (this is a black plastic tab that sticks into the paper path just before the paper goes under the cartridge, and is pushed up or down by the paper). Look for the U-shaped optical detector that is interrupted by this flag, and make sure it isn't blocked by foreign material.
Jun 22, 2011 | Lexmark X342n All-In-One Laser Printer
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
MY PRINTER KEEPS JAMMING THE PAPER AS I TRY TO PRINT SOMETHING. THE PRINTER IS A LEXMARK P4350 ALL IN ONE
First of all check the quality of the paper used, is it of low thickness. if so change with a different type.
If the printing paper is good then the rollers can be moving over with different pressure on the paper making it touch unevenly and so pulling the paper differently.adjust the rollers and if possible tighten so that it touches evenly.
The roller will now move the paper without any side pulling and jamming.
Sep 01, 2010 | Lexmark P4350 All-In-One InkJet Printer
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
How do i clear a paper jam
The Lexmark Printer you are having a very sensitive printer.
Normally this tyoe of Printers are very very slow in Printing job.
Comparing with other laserjet used.
If the Laptop / Printer are under warranrty, the Service engineer
can rectifity the printer jamming.
Solutins :
Make the Printer - Monthly service compulsory.
Use only good quality paper in the Lexmark Printer.
Do not pull the paper through hand, when the print out is coming.
Regards
Jul 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X2600 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
