Question about Ardisam Inc Earthquake Mini Cultivator
Hello, I have a discontinued earthquake model 7065V rear-tine tiller with a 208cc viper engine. I recently moved and 3 plastic parts (air cleaner: housing, base and cover) on the engine are broken. Who can I contact to get replacement parts if possible. thanks. kirby
boscia
  • 163 Answers
SOURCE: older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Posted on Nov 30, 2008
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
trippssmengi
  • 76 Answers
SOURCE: Craftsman Front Tine Tiller 6.0HP/26" -- can not start it
First check for spark, if you have spark than you can try spraying a little fuel into the carb and try to start it if it starts then dies its the carb
Posted on Dec 27, 2008
SOURCE: craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
Posted on May 26, 2009
SOURCE: Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Posted on Jun 01, 2009
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
208cc to hp
208 cc = 8 to 9 Gross Torque = 5.5 to 6 hp
The following article has a fairly good explanation of how to convert but as the writers writes there a lot other variables that are not account for the conversion.
cc to torque to hp Conversion Update
Oct 16, 2014 | MTD PRODUCTS INC Troy-Bilt Bronco...
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Engine surges
sounds like a carb problem if new bring it back to the store
May 05, 2012 | Husqvarna DRT900 960930011 17 Rear Tine...
Tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Apr 30, 2012 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
My rear tine tiller, 18 inch - model #21AA40M1029 by yard machine has been sitting in my storage shed for two years and will not crank. I have changed the old spark plug with a new one and I have drained...
need to check for spark---- magneto [magnet-pulse to coil] may have rust causing failed spark can clean lightly with sandpaper but more than likely u need to clean the carb-buy a rebuild kit about 10 bucks -take off carb tear apart and let soak in parts cleaner use a carb cleaner and spray all the nooks and crannys in carb rebuild replace and try firing up because more than likely the carb is completely gummed up from the old gas
Jun 08, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Air cover for 820 Rear Tine tiller is missing
Many times I use a window air cond. filter for this type of thing and then use ty raps or rubber bands to secure. Anything is better than letting dust get into engine.
Mar 27, 2009 | John Deere Garden
Older model earthquake rear tine tiller won't start
Sep 30, 2008 | Ardisam Garden
Ardisam Inc Earthquake Mini Cultivator Logo
239 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Shehu Pro
Shehu Pro
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
