Question about Cisco Aironet 1142 (AIR-LAP1142N-A-K9) Pre-802.11n Wireless Access Point
Blue light instead of green - Cisco Aironet 1142 (AIR-LAP1142N-A-K9) Pre-802.11n Wireless Access Point
  • 449 Answers
Green means the unit is up and running. It turns blue once the first client is associated with the unit. Blue is a normal status.
Table of status indicators is here:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_21a_JA1/configuration/guide/scg12421aJA1-chap22-trouble.html#wp1109177
Posted on Apr 11, 2011
    Problem Solver:
  • 5 Answers
Until the client is Association and then Authentication happens it will show greeen once above both thing happen it will turn in to Dark Blue.
Posted on Jul 05, 2011
How do you make the light green instead of blue
get a green bulb and replace the burned one
Apr 13, 2015 | Televison & Video
Internal fuse
Amps getting power that's good it seems as though either you have a cross in your bridge or you fried your amp
Apr 02, 2014 | Hifonics Car Audio & Video
After installing timer, lights flash on and off.
When lights blink, timer is wired wrong.
Error: The white wire is connected with red-or-blue wire instead of connected to neutral.
Timer has 4 wires: green for ground, black for hot, white for neutral, and red-or-blue wire for Load.
Open following link for wiring instructions and illustration:
http://waterheatertimer.org/Programmable.html#wire
Aug 06, 2011 | Leviton 500W - 6512H-W - Alabaster
Connection problem to phone light turns green instead of blue
Try resetting your headset by pressing power key and volume up key, until the LED flickers in different seqence. after a while try connecting with your device. it should work.
May 24, 2010 | Jabra BT350 Bluetooth Headset Headset
My TV goes on and off on its own.
Bad light engine call Encompass Parts 1-800-639-3328
Feb 08, 2010 | Televison & Video
LIGHT ON THE SPEAKER BUTTEN STAYS ON
If your speaker button doubles as an in-use-indicator , You most likely have a reverse polarity, This is not usually a problem because the phone will work either way, This only happens with some systems, Check your wall jack for Red and Green wires. The Jack Red Wire should be (Depending on your house wiring) attached to a Red, Blue, or Bluewhite wire and the Green should be attached to a Green, White/Blue stripe, or White/blue striped. Yellow and Black was intended for line 2 but may have been used instead. I hope this helps you
Dec 05, 2009 | General Electric 25982EE3 Twin Phone
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Feb 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Speaker replacement
They still follow the GM standard:
LF+ tan
LF- gray
RF+ light green
RF- dark green
LR+ brown
LR- yellow
RR+ dark blue
RR- light blue
Note that if you're looking for them behind the radio, some of the same colors may be used on other wires. The speaker wires should be placed side-by-side for each speaker.
Also, if you're replacing the factory radio, I highly recommend buying a wire harness adapter instead of cutting off the factory plug.
Jun 05, 2008 | 2005 Pontiac Sunfire
Intuos3 Tablet's pen is not working
Try reinstalling the software that came with the tablet.
Dec 29, 2007 | Eaton 30311 Tablet PC
Cisco Aironet 1142 (AIR-LAP1142N-A-K9) Pre-802.11n Wireless Access Point Logo
4,833 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
