Question about Hoover Vacuums
The base is not sucking ,only the hose works - Hoover Vacuums
    Sergeant:
    Champion:
  • 334 Answers
Is the beater bar turning ???if not belt broken if so tube from beater bar to hose stoped up
Posted on Apr 11, 2011
I have a DC41 Animal. It has suction through the hose. When I try to vacuum it stops sucking through the hose but seems to have no suction in the base and the beater roller doesn't work.
Check for a clothes peg at the motor iintake port. They can get that far then jam at the curve so tight youll wonder how you missed it. It will drastically reduce suction yet not cause a clog , and you can't see it
Feb 09, 2017 | Dyson DC41 Animal Bagless Upright Vacuum...
Vaccum blowing not sucking
Sounds like you've got a plug. Take the hose off, it should be plain to see if its in the wand or in the hose. Work your way from the bottom to where it goes into the bag but it's almost always in the base where the dirt turns to go up the hose. There may be a trap door on the bottom of your machine giving you access to that particular spot.
Good Luck!
The Vac Dr.
Dec 27, 2012 | Sebo Automatic X1 Bagged Upright Vacuum
I think that I accidentally sucked up a child's
if you have a shop vac you can try blowing it out. for some reason this works better. You also might try a coat hanger with a U bend at the end.
Aug 09, 2011 | Electrolux EL6988E Bagged Canister Vacuum
My attachments won't ****
Hi
If the machine is picking up from underneath the hose must be blocked. Try dropping a coin into the hose and see if it comes out the other end
Rob
Feb 13, 2009 | Hoover U5262-900 / U5260-900 / U5266-900 /...
My bissell cleanview is blowing not sucking in the base. the hose works fine and the bruch appears to be rotating fine.
Try reversing your hoses.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 30, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dyson DC14 won't **** from hose but works fine otherwise
There is probably a clog in the U-bend on the back of the unit at the bottom. Removed with a twist of a plastic screw by a coin or screw driver. If not in the U-bend check in the hose/wand.
Nov 28, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
I was vacuuming and part of a towel got sucked up, but not into the hose, and now it isn't working. I turned it off, unplugged it, and the hose still works with the attachments, it is just the base
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=833476
Generic problem for all Vacuums
Posted by melly6483 on July 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. 1st. I do not know the brand name and model # fr the vacuum so the next time include that type of information. So, if you removed the towel from the hose section then there almost has to be something in the powerhead and the power nozzle neck there would have to be a clog and you need to open the powernozzle and look for a clog of some sort in the power nozzle or the wand section that would block the flow of the dust and dirt to the canister section. Check your owner’s manual to see the trouble shooting section for unclogging your vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 25, 2008 | Vacuums
FLexible hose has no suction
It is possible that the hose at the base has deformed under suction and is blocking the airflow. I have found this to be the case on mine. Air is being drawn in from a bypass valve near the base and to the left of the hose so it makes a suction noise but does not have any pull at the nozzle.
Jul 11, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Eureka Enviro Vac Model 4470 Not Sucking
First, check to see if there is suction without the hose on the base. If not, and there is no blockage, the problem is likely a damaged impeller, the small fan that makes the suction. That will have to be replaced.
May 21, 2007 | Eureka Smartvac 4870 Bagged Upright Vacuum
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
75 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
