Question about Magellan RoadMate 1412 Car GPS Receiver
Everytime i turn on my gps it just shows a laptop and a usb sign and a memory card?
  • 21 Answers
If you are not connecting the GPS to a computer, than the USB power source you are using is not compatible with your GPS. It may slowly charge the GPS but I suggest you obtain compatible power supply if you plan to use it in a car.
Here is a link to one such power supply for your GPS
Posted on Apr 11, 2011
I got a vtech kidizoom recently. every things works till i try downloading the file. when connected to the laptop the screen on the camera shows pc connected and the usb sign. however i cant file the file...
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Mar 27, 2013 | Vtech Kidizoom Digital Camera
Sd card trouble
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 29, 2011 | FUJIFILM CD-R Storage Media
Everytime i turn on my tomtom f10 it showes a piture of the sd card with a cross through it. how do i fix this problem
there is a problem with your sd card. try taking it out and giving the conections a good clean and push it back in but make sure you push it in as far as it will go, if this doesn't work try connecting it to your computer via card reader or usb cable. if you cant access it then it is ready for the bin.
Sep 24, 2009 | Tomtom ONE 3rd Edition GPS
USB card memory drop & files lost
Your card is showing signs of improper removal or virus infestation. I would run a virus scan on it at once, back up any remaining data (after scanning of course), then follow the instructions when you remove the card from your computer. Not shutting down the card before removing is similar to turning off your computer without shutting down first. Usually it's ok, but it can cause data loss.
Good luck.
Mar 08, 2009 | SanDisk 8GB microSDHC Memory Card with...
Please help me fixing my gps
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Dec 22, 2008 | Tomtom One XL GPS Receiver
USB Flash Drive
- Click Start / Run / diskmgmt.msc {OK}
- Right-click the memory card, then create a partition & format it.
Jul 03, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Map problem
There are two type of maps in the unit. There is the basemap which shows the states and major highway and roads and then there is the actual Mapsource maps which shows the streets. If you go to Mapinfo and it doesn't show anything, then Mapsource maps are missing.
With the 2610 you can use a card reader for the Compact Flash Memory card to load the maps. This is much faster since the card reader is USB 2.0 while the Garmin USB is 1.1 Under device look for the drive letter which correspond to the Campact Flash card.
Oct 15, 2007 | Garmin StreetPilot 2610 GPS Receiver
Tom tom one
This would suggest the card may be faulty. If you have a backup of the info on the card, try formatting the card and restoring the data.
Jul 12, 2007 | Tomtom One Europe v2 GPS Receiver
Magellan RoadMate 1412 Car GPS Receiver Logo
102 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
