Question about Cycling
Gentlemen: I have the Graber mountaineer-rak What do i do with the ends of the straps that hold the rack onto the car tie them back onto the rack? and What is the best way to secure the bicycle to the rack. The pieces of shock cord with the nob on the end do not seem like they would hold the bike on rack over over a bumpy road Are there special clips?
    Genius:
  • 1,788 Answers
Wrap the shock cords (or bungee) around the bike frame and back onto the rack. Buy a pedal sock, and extra bungees also. Tie the extra ends to the rack itself so that they are not flapping around. A bicycle dealer will be glad to teach you all about it.
Posted on Apr 15, 2011
Problems with steering
Most steering rack and pinions are mounted on the front frame of your vehicle. Follow your tie rod ends from the front wheels inward. They screw onto the rack by the inner tie rod ends.
Jun 17, 2017 | Lincoln Cars & Trucks
How can I tell if my tie rod ends are bad
Is this a motorcycle question? Motorcycles don't have tie rod ends. If you are referring to tie rod ends on a car, you need to jack up the front end, grab hold of the tire and move it left to right, back and forth, while watching for any play where the tie rod ends attach to the steering knuckles (to check the outer tie rods). Then do the same while watching the tie rod where it goes into the steering rack (to check the inner tie rods on a rack and pinion type steering system). I hope this help, good luck!
Oct 29, 2013 | Motorcycles
What is the price for a set of Kayak Racks?
I have been to many boat and caravan shows and lots of people seem to be tending towards inflatinflatable boats because you don't need to put them on the roof racks. Just fold them up and into a bag and on the back of the car.
I saw these are new from www.swellboats.com
Jan 17, 2013 | Boating
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
Rack and pinion? have play in wheel no sign of leaks new power steering pump installed
Hi Gunny, If your vehicle is fitted with rack and pinion steering also check the rack ends for play. The rack ends are the rods which the tie rod ends screw onto. The other end fits onto the rack of the rack and pinion. To work on those you will need to remove the rubber boots and loosen the locking washer, they can then be loosened with a wrench. If they are worn the play will be evident in the steering. When replacing them also replace the rubber boots. If the boots are worn and road grime and dust enters, you will see leakage from the rack and pinion in the near future. I always thought the Dakota was fitted with a steering box? Regards John
Jun 24, 2012 | 1990 Dodge Dakota
Outback Bike Rack Side Straps?
use your own or get strap / webbing and buckles from any upholstery retailer
Aug 20, 2017 | Cycling
The left side tie rod seems to have slop on the rack & pinion side. Tie rod outter end is good.what is it?
Worn inner tie rod joint,on the steering rack
If you go to an alignment only shop, not some
chain store, with an alignment rack,they will
change it for you, if it can be done
Then you have to set all the front end adjustments
Don't let them pitch you, a complete rack assy
Moog-- makes those inner tie rods, and you put your
good outer joint on it
Dec 02, 2010 | 2005 Mercury Mountaineer
How are the tie rod ends connected to the rack unit at the opposite end of the tie rod from the wheel ? The Tie rod is free to turn. Is this normal ??
The inner tie rod is threaded onto the rack. There is a tool called an inner tie rod end tool, than will help make it a lot easier to remove. The tool can be found at any good parts store or tool store. The shaft of the inner tie rod will spin. It has a ball that is pressed into a socket. The socket is the part that has the threads onto the rack.
The way you tell if they are back is by grabbing the tire at the 3 and 6 position and pushing/pulling. If you feel any movement than look carefully at the inner tie rod and the outer tie rod to see which one is letting the wheel move.
Sep 27, 2010 | Oldsmobile Silhouette Cars & Trucks
Repair inner tie rod end of 1997 dodge avenger
f734654.gif #3 is the inner tie rod and it is simply screwed into each end of the steering rack. Raise and support the car remove the wheel and you should see where it is connected to the outer tie rod. There is a lock nut that you'll need to loosen slightly to get the tie rod off. You will need to get a wheel alignment once done but by slightly loosening the lock nut, you have a good reference of how it should be once done. Once loose, you should be able to turn the tie rod by using a wrench on the flattened area on the rod. Once disconnected from the outer tie rod end, you should be able to remove the dust boot covering the inner tie rod connection. Mine came right apart so hope you have no problems. After you have it out, here is where the loosened locknut comes into play. Put the new and old tie rod side by side, line up the ends that attach to the rack and pinion then mark the new rod so you know how far to put the lock nut on the new tie rod. Simply tightly screw the new one onto the rack and pinion put the boot back, screw on the lock nut to the mark then attach the tie rod to the outer tie rod end up to the lock nut then tighten the lock nut against the outer end. Get the tire back on, lower the car and Voila, done. Now go get an alignment.
Nov 18, 2009 | 1997 Dodge Avenger
Rack pinions and bushing installement
pretty decent job ahead first jack up car support with jack stands remove front wheels remove nuts on tie rod ends remove tie rod ends from spindles with tie rod end tool or tap with malet were they sit to loosen them hit the spindle area not the tie rod or tie rod threads then dissconnect power steering lines from steering rack also disconect steering linkage to rack there should be 2 main bolts holding assembly to frame remove them should free rack i know that car may have a unique design were u may have to remove inner tie rod ends first if it has those round bushings that always go bad disconect inner tie rod ends behind engine on top of steering rack then remove rack from wheel well replace those inner tie rod bushings u may be able to leave outer tie rod end connected to spindles and u may be able to get to the sterring rack from behind engine good luck
Mar 28, 2009 | 1997 Chrysler Concorde
Cycling Logo
360 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
