Question about SimpleTech 320GB SimpleDrive External by Fabrik 320 GB USB 2.0 Hard Drive
My SimpleDrive 320 is being recognized as "storage" with no drive letter designation. Ideas?
  • 4,281 Answers
Connect harddrive to computer then when you power up the computer press F8 key 5 to 6 times then enter in safe mode then if still letter will not assigned then follow below.First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Posted on Apr 11, 2011
I have a Simple Tech external HD that has been working fine but now my PC won't recognize it and freezes up when I have it plugged in. I get the blump sound when I plug it into the USB port but t
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement.
Incompatible USB Port Problems W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts b> SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter b> If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. Enable Drive Letter View b> Click the "Start" button and choose "Control Panel" from the start menu. Click "Folder Options" and navigate to the "View" tab. Scroll down and place a mark next to "Show drive letters," then click "OK." b> Configuring Drive Manager b> Click the "Start" button to launch the start menu. Right-click "Computer" and choose "Manage" from the menu. Click "Storage" in the menu on the right side to extend the section. Click "Disk Management" under the "Storage" header. This will show you a list of drives and removable storage on your computer. It will also report the status of the drives, such as "Healthy." If the removable storage does not have a drive letter or has a drive letter in conflict with another drive, you can assign it a new letter. Right-click the icon of your removable storage drive and click "Change Drive Letter and Paths." Click the "Change" button, then choose a drive letter from the drop-down menu. Select a letter that is near to the end of the alphabet to prevent drive overlap issues. Click "OK" to allow the changes to take place. You should now see the removable storage listed with your other drives on the "My Computer" screen. SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible b> If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing. Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted. b> Replacing a Defective Hard Drive b> You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services. Hope this helps.
Jan 22, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
Ihave Simpledrive 500GB external hard drive but now all of a sudden my PC does not recognize it when I go to my computer and look for it
Jan 07, 2013 | Compaq Presario 5000 PC Desktop
Trouble getting my computer to recognize my simpletech hard drive
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
RightClick on Volume (C:>) for Change drive letter and path.
Dec 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Dec 29, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Not being recognized by computer
Is that external???If yess just buy new external...
Dec 10, 2008 | SimpleTech SimpleDrive 250GB, 7200RPM,...
My 320 GB usb drive is no longer recognized by my computer.
Very simple solution. Your external storage cabinet for the drive is junk. I opened mine up and its just fitting loosely in it. You will void your warranty if you do - but who cares, the cost to send it in for an RMA is equal to the cost for a 2.5" SATA enclosure. When you open it up, the SATA and Power connector is not all the way in - push it in and then tape it so it holds together. Plug it in and you should be fine. Fixed two of them that way.
Nov 20, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleDrive external USB Disk Drive
You may not see any icon on desktop but should see "found new hardware" at the bottom right by the time. Right click My Computer and click Manage. Under Storage click Disk Management. You should find your drive here. If its a new drive, no letter may be assigned or it may not be partitioned or formatted yet. Right click on the drive to format it and to assign a drive letter. If its already formatted and works on other computers, let me know because it could be a USB error or faulty cable.
Nov 07, 2007 | SimpleTech SimpleDrive...
SimpleTech 320GB SimpleDrive External by Fabrik 320 GB USB 2.0 Hard Drive Logo
52 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
