Question about Keurig Platinum B70 Coffee Maker
When I press brew, the water does not pump through and nothing happens. How do I get my keurig fixed?
    Brigadier General:
  • 3,917 Answers
Hi
You have to pull off the little mushroom-shaped gasket first, then use a straightened paperclip and stick it into the 3 openings on three sides of the upper needle, moving it around for 15 seconds in each opening. Replace the gasket and then, by not inserting a k-cup, flush plain water through the needles for 3 different 6-oz brews (use a measuring cup to check). If you are still getting short-cups, you will likely need to call customer service. Make sure to clean the lower needle too - the instructions are in the book - but be careful not to break the funnel cover when removing.
Also check this useful link :-
http://www.ehow.com/facts_7563004_keurig-b70-not-brew.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 11, 2011
Why did our keurig b70 just quit working?
Try unplugging it for 30 sec. and plug back in. Give it time to reset. Hope this helps
Feb 05, 2018 | Keurig Platinum B70 Coffee Maker
Will not brew . says ready to brew but when I press brew button nothing happens
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101]][[]
Aug 19, 2011 | Keurig Ultra In Home Single Cup Brewer...
My Platinum Keurig says it is ready to brew but nothing happens. I have cleaned out any coffee grounds.
My B70 has worked good for about 6 months. Lately it won't brew a full cup of coffee or water for that matter. I have run Limeaway, and also vinegar throught it but nothing works. It seems to me the pump is too weak to make coffee before an apparent time-out occurs.
Dec 15, 2010 | Keurig Platinum B70 Coffee Maker
I have the Keuirg mini plus and i just opened it. It flashes red like it is heating and then just turns off. No brewing.
Same here. (I have the Mini Plus B31) Called Keurig and these are the steps they walked me through. Not sure which part actually fixed the problem, but it worked.
1. Turn off machine. Using a paperclip clean out the holes in the needles (3 in the top, one in the bottom of the k-cup holder).
2. If water is inside the heating core (assuming it is as nothing happened when you tried to brew), with the machine turned off, press and hold the brew button. After 5 seconds the pump will kick on and discharge the water. Make sure you have a cup in place to catch the water.
3. Dispose of that water.
4. Unplug the machine.
5. Wait 5 seconds.
6. Plug machine back in.
7. Turn on.
8. Run empty cycle without a k-cup and only use the minimum amount of water (6 oz).
9. Dispose of that water after it brews (hopefully).
If still nothing is happening, call Keurig.
10. Brew your coffee, tea, choco, etc.
Note: was told by Keurig rep that whenever you use hot chocolate, to run an empty rinse cycle afterwards before brewing another cup. This will help prevent any choco from going up inside the machine and possibily blocking the water flow.
Hope it works! Mine did after following these instructions. The rep also wanted me to measure the amount of water that came out afterwards. Not sure what the next step would be because my call got dropped, but the machine works. Sipping on a cup now...
Oct 16, 2010 | Keurig B60 Coffee Maker
It says it's brewing - - But It is Not???
If it won't pump water through, how are you going to run a descale? Also this model is supposed to tell you if scaling is an issue. We called Keurig, they said, we will send you a new one.
Mar 21, 2010 | Keurig Platinum B70 Coffee Maker
My Keurig platinum B70 will not pump water through the system. It says "Ready to Brew",I push the brew button, it says "Brewing", but nothing happens. It also defaults to the largest cup size, and will not...
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Dec 01, 2009 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
