at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
> Home / Repairs DIY washing machine advice (part 8)
Washing machine sticks or stops mid-cycle
A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty
hope you can find what you need starting from the above, if i have helped please rate me
