Hi, In My Computer the Speakers are attached and they are Plugged in the right place But am not able to get the Sound out of them. I even have downloaded Winamp then also it is not Coming. Please suggest me Which Software or Installer i have download. Thanks And Regards. S.M.Asifi
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 11, 2011
Speakers not working
try to check if all the cables is plugged in. if it's plugged in right, try plugging out the cables of your speakers and after doing that, plug it in again and try the speakers if it's working.
thank you for choosing fixya.
Jan 14, 2012 | Audio Players & Recorders
Even though the speakers are plugged in,turned on, and at full volume, there is no sound. The speaker itself still works because when I plugged in my ipod, sound still played. The speakers only don't...
First we need to check if we rightfully plug the speaker in it,s rightful socket at the back of your computer. There are three sockets one is for the mic the other one is for the speaker and lastly the input socket. the green socket is it's rightful place. So now we can proceed, make sure that you have a proper sound driver for your computer. If it is still not installed, we really cannot hear anything from the speaker that we just plug in. Try to re-install your motherboard drivers, especially the sound driver for *********** board. If you don't have an installation disk, then try to buy or acquire a driver magician installation disk it is available at any software stores. After you installed driver magician, it will automatically detect any missing drivers that your motherboard needs. Try downloading each one by pressing download and driver magician will automatically search the web and download it for you. All you got to do is install them. I respectfully hope that this would solve your problems. Have a nice day friend.
Aug 17, 2011 | Micro Innovations MM635F Computer Speakers
The speakers I have worked just fine, then one day they just stopped working. Now my computer doesn't even detect them. They are plugged in correct and I haven't switched anything.
if your computer came with a motherboard disc the sound drivers could be on it
also
hope this helps
Apr 22, 2011 | Polk Audio AMR90 Computer Speakers
We just had our system updated to Windows 7 and for some reason even though the speakers are plugged in and switched on I'm getting an error message stating that they are not plugged in. Is there any...
if you are having problems with your sound
also
hope this helps or you could download
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Update your embedded sound from Realtek to the latest AC'97 codec.
Hope this helps
Apr 07, 2011 | Logitech X-530 Computer Speakers
Right place not working still
1.click Start -> Run … enter:services.msc
2. Click OK, a services window will appear, scroll to windows Audio, double click
3. Windows Audio Properties will appear. Change startup type to “Automatic
4. First click Apply, then click on start to start the service
Hope this solves your issue
Aug 27, 2009 | Ozaki DT-500 3-Piece Speaker System...
Unplugged speakers, plugged em in -- now I don't get ANY sound
check ur sound drivers.. check whether they are uninstalled, and try to check in the sound and audio devices in control panel...
Jul 25, 2009 | Bose MediaMate Computer Speakers
I have plugged in my speakers at right place but no sound is coming out of it. I also have a sound card of realtek nothing is helping. Please provide some solution.
Try changing the setting from the "Realtek HD Audio Manager" Select the correct input jack, double click it then "Which Device did you Plugin " window will pop up select the appropriate option and shall work. If this Does not work disconnect the speakers from the system, remove the sound drivers & reinstall it again, connect the speaker. This shall work now
Jun 25, 2009 | Ozaki DT-500 3-Piece Speaker System...
No sound from speakers
Usually you can see the speaker icon found at your task bar right side if the sound driver was installed. If not better re-install your sound drive.
Thanks
Nov 25, 2008 | Acer (90.18612.36B) Computer Speakers
Speakers hissing/humming
Hi Nate41
you won't do anithyng
may be is a bad resistor inside, that get hot and probably start to do this problem. try disconecting the speakers, and move to other place, more cooler, and try to see if you don't get the hissing and humming sound now. sometimes dust and hot places get to this problem.
beside that, may be a path to a problem.
Nov 26, 2007 | JBL CREATURE II Computer Speakers
Speaker installation
first see to that audio driver is installed in ur computer or not if not put motherboard cd, right click on my computer go to hardwre right click on sound manager with yello question mark and give update driver
Nov 13, 2007 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
