Question about Allen & Heath Xone-22 2 Channel Dj Mixer
I have an allen and heath Xone 22 Mixer. Its great, except due to the lack of a power switch I pulled the ac adapter/power cord out too many times and now it has a really bad, loose connection. It works, but any bump to the chord and it cuts out until i fiddle with it. Do you think a replacement ac adapter would help or does the actual mixer need to be repaired. If so, can that be done without actually sending it to allen & heath (I live in the USA). thanks!
  • Allen & Heath Master
  • 5,603 Answers
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Posted on Apr 11, 2011
I get a static buzzing noise out both speakers. it stops if I hold the plug cable or master out cables? turntable wires are grounded. help!
If this is stopping when you grab a connector then you have a bad solder on the connector. a short or break in the wire or a ground is bad.
Apr 07, 2016 | Allen & Heath Xone-22 2 Channel Dj Mixer
CHANNEL MONTIOR LIGHT WILL NOT STOP FLASHING
You've pressed the "solo" button by accident.
Jun 01, 2014 | Allen & Heath Xone:92 DJ Mixer
Filter Knob and Buttons move from left to right
If you pull the knobs off, you will find lock nuts under them. You could tighten them up. See if the knobs have set screws on them to lock them in place before pulling them off. On Allen & Heath, I don't think they do but, just in case.
Mar 21, 2014 | Allen & Heath Xone:92 DJ Mixer
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
I would like to buy a case for The Allen & Heath ZED-436 is an audio mixer that gives you 32 mono inputs plus 2 dual stereo channels. Which one do you recommend that can fit it well.Please send me...
Cases are being sold on Ebay, new, from several sources, and if you can't find one specifically listed for your unit, contact the sellers as they custom build them. That is a big unit... expect to pay around $150 to $200 for an ATA type case for it.
Here is an example for a Heath/Allen 420. http://cgi.ebay.com/ATA-CASE-ALLEN-HEATH-ZED-420-ZED-420-ZED420-MIXER-/400127078772?pt=LH_DefaultDomain_0&hash=item5d296eb174
I have bought from them before myself and there are others on Ebay so shop around... You can contact the companies and ask for a specific one and DO compare the size to your unit that they specify as all the companies do not accept returns...
Aug 14, 2011 | Allen & Heath AH ZED 436 32...
The internal fan has been making noise and now after 30 min or so we get a loud pop the a descending whine at deafening levels even with the board muted. I'm suspecting an internal supply issue in our...
Hey tifly415, did you ever fix this problem? My church has the same mixer and last night it did the same thing twice during a congregational meeting. No fan noise, but the meters all peg and we get this horrible descending squeal which gets louder as you pull the faders back in a moment of sheer terror and panic. Power it off and back on and it's ok for a while then it happens again. It's happened to me a few times during rehearsals in the past and it definitely is not mic feedback because no one was near the console or doing anything at the time. It seems to be totally random and unpredictable.
I, too, suspect a power supply problem, but it never seems to happen when my troubleshooting gear is nearby. The only thing unusual yesterday was that the mixer was left on almost all day, so it may have been warmer than usual.
Anyone else have the same problem, or better yet, know of a solution?
Nov 20, 2010 | Allen & Heath Allen and Heath GL2400-32...
Hi there my allen heath mixer is weired this
If you use analog outputs and inputs try to clear of it really is your mixer and not one of the inputs. If the inputs are good your mainboard could be a bit dusty or you have a loose contact. If you have a mixer with internal interface your audio stream from your computer might be the problem.
Jan 23, 2010 | Music
Mic section, lights and filter section quit working
Sounds like it MIGHT be a power supply problem. Needs service!
Aug 27, 2009 | Allen & Heath Xone:92 DJ Mixer
Allen & Heath Xone-22 2 Channel Dj Mixer Logo
722 people viewed this question
Top Allen & Heath Music Experts
Michial Gueffroy
L. Sawyer
Are you an Allen & Heath Music Expert? Answer questions, earn points and help others
