Question about Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch
Casio PAW-1200T Tough Solar Pathfinder watch says OPEN. Watch has never been opened, and solar battery has full charge. Nothing works but the basic time and the light.
So here is the fix if you get op en display on your casio pathfinder or whatever model. mine happens to be a paw 1200t
1. you gotta break it open 2 pins each side band comes off.
2. pry off the side pieces. this exposes 4 screws.
3. the base then comes off be careful of the gasket.
4. once inside. notice a round circular object on the base and a small oval shiny gold copper piece.
5. For whatever reason the shiny copper piece has shifted and does not make contact with the tiny little springs there are 2 if you shift the base to make contact with the gold piece the op en goes away and watch is back to normal.
6. the fix is move this little piece back to where it belongs. i got lucky and the glue still held when i firmly moved it to its original location. super glue came to mind if it wont stay where it belongs.
7. gasket orientation and cleaning out the gasket channel is a given i used welding tip cleaners to do the intricate work. under the bands are very grungy. mine is about 5-6 years old. reassemble the way it came out.
if your battery is good and you get this op en look to your display for whatever reason this worked for me and if casio uses this as a warranty or warning of water coming in your watch it was a STUPID DUMB IDEA. those springs should be solid state and the watch is useless until it is fixed no light, no baro, no alt, no comp. notta and no buttons work. there is no reason whatsoever that this shiny copper thing shifts but it happened to me and my watch is working and my battery has had H or full power since day one.
Posted on Feb 12, 2013
  • 1 more comment
  • rank Oct 07, 2013
    thank you craz z
  • Ryk Scott
    Ryk Scott Oct 13, 2013
    Thanks for the tip. I'll either send it to Casio for repair or buy a newer model.
  • maarcangeli
    maarcangeli Nov 24, 2015
    Great tip! Worked for me!
5 Suggested Answers
  • 10 Answers
SOURCE: need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
SOURCE: casio-womens-lcf30-4b-tough-solar-ana-digi-sport-watch instructions
Try this link to Casio site:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2790&submit.x=0&submit.y=0
Posted on Nov 29, 2010
Ezrahite
  • 2632 Answers
SOURCE: I need an Instruction Guide
Welcome to Fixya. Can you please check the back of the watch to determine the model number. You can refer on the image below.
Thanks
Posted on Jul 30, 2011
How to set time casio paw 1100 1v
On pages 2 and 3 of the manual (module 3043) you can find the instructions for automatic and manual time setting.
The manual can be downloaded here (direct download link):
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3043.pdf
Jun 24, 2014 | Casio PATHFINDER ATOMIC SOLAR WATCH...
Paw-1200t
may be some dust inserted into the watch which prevents you to press the buttons .
another prob might be low battery. put your watch in sun in order to give some power to your solar battery
Nov 11, 2013 | Casio Triple Sensor Pathfinder PRG60-1AV...
The word "LOW" always appearing
The word LOW means that the solar battery charger is not charging. This could be a defective charger or you're not out in the sun long enough to keep it charged.
Feb 06, 2011 | Casio Protrek Triple Sensor Tough Solar...
I need an instruction manual for a Casio Pathfinder watch. I show PAW-1400T-79VCR on the box as the number. Can u help me find one? It has a solar battery, digital compass, altimeter/barometer and...
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Aug 13, 2010 | Bulova Watch
I just bought my casio pathfinder paw 1100 wsatch and my alt and baro doesnt look like is working
http://world.casio.com/wat/download/en/manual/
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
May 07, 2010 | Casio PATHFINDER ATOMIC SOLAR WATCH...
I have a Casio Pathfinder PAG-70 that reads "OPEN" on the display where the date should be. It is a solar powered watch and shouldn't need a battery change. Any ideas?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 15, 2010 | Casio PRG-40T-7 Pathfinder
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
Not very helpfull
Because it is not a documented problem for this watch in the user manual to be found at http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2767.pdf
Are you sure you acctually have a Casio Protrek Tough Solar Ana-Digi PRG-60T unit or do you perhaps have some other model of Casio watch and have posted in the wrong place on the forum?
Jan 17, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Jun 20, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
3,294 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
