Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Temp. not holding up in the RED Model #59587990
Hi, Its me again. I had a tech to come out. When the tech got here everything was working fine. We explain to the tech that evey week the temp will go up and down and the ice trays will melt. He told me to call when the refrigerator was not cooling. He did tell me that it could be the relay or the thermostat. He said if it is running and not cooling its the relay and if its not running and not cooling it the thermostat. Charge me a service fee and told me to call when it is not cooling again. He never check anything. Now the temp. is up in the red and my food is warm. Any suggestions?? Thanks again for your help.
  • 828 Answers
Call the man when it is acting up as he asked. If you turn on a light switch and the light comes on nothing can be found wrong. When you turn on a switch and the light does not come on someone can determine if it is the switch or the bulb that is the problem.
If the compressor is running while there is no cooling it could be such a thing as moisture in the system.
If the compressor is not running while there is no cooling it could be the thermostat control, or if the compressor is hot and not running it could be the relay as he stated but the condition must be evident for anyone to find it.
Posted on Aug 07, 2008
I have a 2003 alero with the v-6 what happened was driving down the road the heater works fine. then all of a sudden it was blowing cold air and the temp gauge started climbing. it started blowing how air...
Sounds like the water pump is cavitating . Replace water pump. Check coolant level also. Open the bleeder valve usually located on thermostat housing to remove air from system. close valve when coolant is present while filling. close radiator cap and top off recovery bottle to correct level. These engines are prone to overheating, do not let temp gauge get in the red.
May 01, 2017 | 2003 Oldsmobile Alero
Hi OldTech, Whirlpool Acubake electric oven stopped working after it suddenly displayed a flashing F2EO error message accompanied by a persistent beep. I unplugged and plugged it again. Thought it...
Hi
F2-E0 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 21, 2011 | Ovens
Tecra M4 with blank screen or colors wrong (red instead of black)
THis happened to my Tecra M4 4 times in 4 years. Each time was a motherboard replacement at the tech repair shop. Each time cosint about $600. I have heard of the heating method to reflow the solder but don't know how to do it. Others have paid for the motherboard replacement and modded the GPU fan to constantly run. I may get it fixed once more and try using a laptop cooler to keep it from overheating again. Because it is soldered on to the motherboard, they replace the entire board.
Jul 13, 2009 | Toshiba Tecra M4 Notebook
Gas heater won't work
Which flame sensor did he replace? The pilot flame or the plenum temp. sensor.
Dec 14, 2008 | Carrier 38CKC036 Air Conditioner
Temp not holding. temp up in the 60's
Possible poor connection where the fan was replaced on 6/9. Possible bad switch that turns the fan and light on and off as the door is used.
Jul 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Bose Cinemate Home Theater
Hello everyone! The Bose interface module is working again. All I did was unplug the power, wait about a minute and then plugged it back in. Whatever it did, it must have reset itself, so now everything is fine.
Nov 18, 2007 | Bose Cinemate Digital Home Theater System...
TV problem
  • it is 100% sure the problem is in red video output ckt only.
if you familiar with electronics please check the following.or call tech.
  • crt base for loose.
  • connector to crt base loose.
  • supply to red video output transistor ckt.& red video output transsistor.
  • components related to red video ckt.
  • red video signal coming to red video output frem processor.
  • hope this will help.
  • good luck.
Oct 17, 2007 | Televison & Video
Need help with dishwasher
I misplaced my diagnostics paperwork, but I found you here and you saved my life!  The wife is much appretiative!
~Teddy Bear
Jan 24, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
