Question about Maytag Dryers
I bought a non-working LDE882 Maytag Dependable Care + dryer at a garage sale in hopes of resurrecting it for my laundry room. PO replaced the belt and claimed he "may have dislodged some wires" when putting everything back together. After looking at the parts diagrams and schematics, it could be just a loose wire or other bad switch. What would you check first?
  • 1 more comment
  • docdcmail_co Apr 12, 2011
    Many thanks, manual is downloading now (real slow connection tonight).
    OK, I wired in a new 4 prong cord tonight, shut the door and set to normal dry, pushed start and buzzer sounded (it does shut off with rocker switch) and the damp monitor lights lit up along the bottom most row with a flash, but No tumbler action. Dial had ticking noise like the timer was working, but when I push in "press care" button and hit start, nothing lit up.
    Since I need to reverse door hinges anyway I took off front panel and pulled door switch to take to work to check with mult-meter tomorrow. I did see 2 wires loose in there. One was a blue wire (~18 ga) with a female spade end. Could not match it up with anything that it would reach. The other was a green ground, again with a female spade, but nothing to mate it with. It was attached to the right side of the drum support. The blue wire routed back toward motor, but came out of the harness with the 12 ga purple that goes to the heater.
    I'll check those things you mentioned Moby (lol) and get back here Tuesday eve.
    Could those 2 wires go to the "dryness sensor" on page 68? It does not seem to be there on this dryer?? There are holes for it, but she's a gone.
    I pulled the 160 degree therm and tested BK-PU for continuity per instructions. No continuity. I guess this means bad component, right? I did get continuity between RD-PU if that makes any difference in the troubleshooting. Door switch metered out good, as did both thermal fuses (cutoffs).
    Blower fan was a tiny, tiny bit worn looking on the shaft flat side, but turned the drum when rotated by hand, so I presume that to be a good sign. Not sure what it does when it gets up to speed, though.
    So, right now, I am thinking I need the dryness sensor and the 160 thermostat, and some rubber feet.
    Not sure what to check up top in the control panel, just figured on getting the lower figured out first. It's gonna as clean as it was new when I finish with it. Just hope it works, too!
  • Maytag Master
  • 8,220 Answers
Let me see if I can get a photo of the motor and pulley. Its tricky because if you mount the belt wrong it won't run. The slick side needs to be towards the drum and the belt CANNOT be in the groove on the drum
The wires are all numbered to mate numbers on the motor switch. The lid switch can be tricky. I would check that and all the limits.
Posted on Apr 11, 2011
Testimonial: "Thanks for the quick response. I will check all this tonight."
  • 4 more comments
  • Dan Webster
    Dan Webster Apr 11, 2011
    That's a nice dryer. Well worth fixing. My opinion
  • Dan Webster
    Dan Webster Apr 12, 2011
    Ok I am gonna dig deep in my stuff and yank out a service manual for yall: Mid 90s maytag dryer
  • Dan Webster
    page seventy five shows the location of the duct fuse. If blown the dryer will not run. MORE:
    The blower wheel on these tends to wear out and slip, reducing the volume of air in the drum and causing overheating. Clean it up cheak all that and let me know dude.
    See my reply under comments.
  • Dan Webster
    Dan Webster Apr 13, 2011
    The wires are numbered for the dryness control to the board but I do not believe the dryness control has anythang to do with the motor running.
  • Dan Webster
    Took a few pics today of a dryer I worked on like yours
    I shoulda included see above pic. LOL
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
Mar 15, 2015 | Maytag Dryers
Overloaded washer, smelled burning. Washer works
On this machine, you most likely just burned the drive belt. The old dependable care transmission design was pretty hard to kill, so just get yourself a new set of drive belts. Very easy to replace/install. You can just tip the machine back to access them. There is a lip on the bottom of the front panel that will hide the pump belt but enough room above it to unwind it off the pulleys. If you want, the front panel can be removed, early models used two phillips head screws to hold the front on or later versions used two clips on the bottom that you can release with a putty knife. Pull the bottom of the front panel forward to un-clip the top and away you go.
Jul 02, 2010 | Maytag Dependable Care LAT9206
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Aug 08, 2009 | Maytag Dependable Care LAT9706
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Dryers Logo
313 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
