Question about Philips PM435S Remote Control
Phillips SRU3004EM/17 , I need to reprogram this thing.
The red indicator light on my remote is on and will not go off. I cannot program it because it seems to be stuck. How do I reset the remote?
    Champion:
  • 226 Answers
Check to see if a button is stuck down. if this is not the case try slamming the remote on something hard. if that doesn't work your remote is broke. Resetting will not help. Throw it away and by the original remote, which you don't have to program from www.replacementremotes.com
Posted on Dec 23, 2008
I am trying to program a Phillips universal remote control model# srp5107wm/17 to use with my legend L2628 TV and I can't find a code that works. Help?
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 24, 2012 | Philips Televison & Video
I have a Phillips SRU3006WM/17 remote I need the
just press your setup button untill the red light stays on then hit TV or what ever your trying to program then keep clicking channel up until the channel changes and once it changes hit enter or setup button
Jan 08, 2010 | Philips Televison & Video
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
Reprograming
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 20, 2008 | Philips Televison & Video
I need the codes for a universal phillips remote controler
Hope this helps :)
Jun 14, 2008 | Televison & Video
Need code for phillips remote
Hope this helps :)
Jun 09, 2008 | Philips Televison & Video
Please help!
Hope this helps :)
Jun 06, 2008 | Philips Televison & Video
Manual
Hope this helps :)
Jun 01, 2008 | Philips Magnavox Learning Universal Remote
I changed batteries in my remote and i cant figure out how to reprogram it
Hope this helps :)
May 13, 2008 | Philips Universal PH301S Remote Control
Phillips directv remote RC19041003
see page 13 of this manual
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX5500_5540.pdf
May 01, 2008 | Televison & Video
Philips PM435S Remote Control Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
