It just dont functional at all..no activities ..
    Genius:
  • 1,456 Answers
Hello
First of all read the manual that came with the printer. If you can't find it then you may be able to download an Acrobat pdf file of the manual from the manufacturer's website. This could save you a lot of time!
Make sure the printer is turned on. Are any lights flashing that could indicate a problem? Can you clear the problem by turning the printer off and on again? Have any settings been changed - consult the manual before changing them.If the power switch is on but there's nothing happening and no lights lit check the power supply and transformer if there is one. Is there paper in the tray? Is there a paper jam? If there is, try to extract the paper gently - forcing the paper could damage the mechanical parts or the drum. Open up all the available doors, inspect the paper tray and duplex area if there is one, and remove and replace the toner cartridge.
Disconnect the parallel cable that connects the printer and the computer. Check the ends of each side of the parallel cable to check for any broken pieces or frayed wires that may be causing the errors in which you are troubleshooting the printer. Try using a new cable to isolate the printing problems and see if the printer errors are caused by the cable.
Most printers are plug and play meaning that if you open up the box and plug it into your pc it should work, however time to time you will need to install the software drivers so that your printer can talk to your pc. If you plug in your printer and it does not recognize the pc the first place to check is the software that came with the printer and install the drivers that came with it.
In some cases if you can't find the cd, almost every printer manufacturer has a website that you can download print drivers from. HP and Gateway are really good about maintaining up to date drivers for their printers.
Posted on Apr 11, 2011
Headlights 2000 Chevy astro van dont work they come on some times but go right off i think theirs a ground loose or some thing new battery new alternator
I'd check the headlamp relay in the under hood fuse / relay box to start . The relay is energized by the BCM - body control module !
Voltage is available to the headlamp and panel dimmer switch at all times. When the headlamp and panel dimmer switch is activated, the two following actions occur via CKT 352 (WHT):
A headlamp enable request is sent to the body control module (BCM)
The headlamp relay is activated
The VE1 option is equipped with automatic headlamps, which is activated when the photo sensor detects dark conditions. A code will set if there is a fault in the photo sensor, or in the two CKT's between the photo sensor and the body control module (BCM).
The coil output of the headlamp relay travels through CKT 250 (BLK) and is grounded at G101.
When the headlamp relay is activated, power is supplied to both the LH and RH headlamp fuses through CKT 1346 (LT BLU).
LO and HI beam functions are activated/determined by the multi-function switch on the steering column.
The HI beam function must be enabled by the body control module (BCM).
The headlamp power travels through the multi-function switch at the steering column and is grounded through CKT 750 (BLK).
The flash-to-pass function is also activated by the multi-function switch on the steering column. It is powered by CKT 1840 (ORN) and enabled through the body control module (BCM) via CKT 307 (YEL).
Dec 27, 2015 | Cars & Trucks
Hi ,i purchased my dell inspiron laptop recently.2 days onwards,touch pad is not working.could you please help me?
My dear friend this will usually be a problem with the function keys, you might have de-activated the touch pad. Try to check in the function keys and you may find a key with marking of touch pad usually it would be F4 so to activate it you need to Hold Fn+F4 key and try. It will sure work well and this is not a problem with the machine.
DONT FORGET TO RATE MY SOLUTION DEAR
Jun 27, 2011 | Dell F3534 Touchpad
Our systems have detected unusual payment activity on your account. As a security precaution, the payments functionality on your account has been disabled. You will not be able to purchase or use Facebook...
Our systems have detected unusual payment activity on your account. As a security precaution, the payments functionality on your account has been disabled. You will not be able to purchase or use Facebook Credits. For more information, please contact us by filling out the following form (please copy and paste the URL into your browser): http://www.facebook.com/help/contact.php?show_form=payments_activity
Sep 23, 2010 | Facebook Social Network
I formatted my Sony PCG-TR3AP notebook and I dont know how activate function keys.
Function keys depend on software to specify their use. You need drivers. Try;
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGTR3AP
Apr 12, 2010 | Sony PCG-TR3A Notebook
As soon as I login the menu display gets activated automatically
if you dont know what caused this ... restore the system to an earlier date ...one when ya are sure that the problem wasn't present ..
Oct 03, 2009 | Acer AC713 17" CRT Monitor
Bough a sony vaio computer is loaded with vista home premium pack microsoft activation comes up says to convert to full product too dear also can't send email because of it
Follow the activation wizard, you can activate by telephone if you dont have internet access, and that will restore full functionality to windows
Jun 27, 2009 | Computers & Internet
About Audi overboost
Yes it does have the overboost option, so what it does its gives you extra revs for more speed but only for a limited time. To activate the overboost you need to put the pedal to the floor and thats when the overboost kicks in. Make sure you dont have the A/C on as its drains power.
Jun 18, 2009 | 2006 Audi A6
About flash light for nokia 1650
presssing the SCROLL UP button toggles the flashlight function. if you carry the phone in your pocket, try activating the keyguard function (press "menu" then "*" ) this will prevent accidental activation of any key
Oct 14, 2008 | Cell Phones
k24674
