Question about Jenn-Air 24 in. JDB1250 Built-in Dishwasher
Dishwasher will fill and drain, but no water will go through the spin arm.
  • 822 Answers
The spin arms get clogged with food ....
try cleaning the spin arms............
cheers
Posted on Apr 11, 2011
Dishwasher
sounds to me like the pump is not working as good as it should . water pressure runs the arms .look for something plugging it
Dec 13, 2015 | Dishwashers
Sears dishwasher not cleaning
You may have a bad pump, or the pump intake (inside the bottom tray, under the dish racks) may be clogged with crud from years of dirty dishes.
Jul 31, 2014 | Kenmore km 665.15765692 3376066 Det Latch,...
Kenmore model 665
You need to check the arm's holes for clogs. If the water is filling and draining well, the only water that circulates is being pushed up through the center hole or tower.
The angles of the holes cause them to be little jets when the water rushes out. No water getting through = no jet = no spin.
Jun 30, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Top Arm does not spin so glasses are not cleaned and detergent is not rinsed out of holder very well.
Make sure the water level is just at or below the heating element. Low water level will cause the pump to "run out of water" before all wash arms and connecting tubing are filled. A pulsing sound during the wash cycle will verify. Low water pressure or a bad water inlet valve are one cause. Water siphoning ou the drain line is another. Look under your sink and verify the drain line goes from the garbage disposal or sink tailpiece all the way up to the bottom side of the coutertop enroute to the dishwasher.
Apr 27, 2009 | Dishwashers
Lower spray arm won't spin
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Jan 22, 2009 | Maytag 24 in. MDBS661A Built-in Dishwasher
Dishwasherwont wash
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 04, 2007 | GE 24 in. GSD2120C Built-in Dishwasher
Washing
Aug 30, 2007 | GE 24 in. GSD2230Z Built-in Dishwasher
Fills with water but won't wash.
Aug 11, 2007 | Maytag 24 in. MDBH950AW Built-in...
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Jenn-Air 24 in. JDB1250 Built-in Dishwasher Logo
73 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
