Hello! my seagate ST30000CB external hard drive (450gb) fell off a table when running and now the disc doesn't spin. Is it possible to fix it, and if so, who can do it for me? george
    Genius:
  • Computers & ... Master
  • 1,056 Answers
It would cost as much to fix it, as it would be to replace it (if not more).
The hard drives in theose units are the same as any other 3 1/2" HDD in a computer.
They are sealed units.
Plus dropping it could have possibly damaged the disks in the drive, or the read/write heads.
Posted on Aug 07, 2008
I won a Seagate ST30000CB, Part # 9Y7865-560 Serial # 5QF3J7W7 and need get Seagate Disc Utility CD. How and where can i get same or how can I download ?
I'm not sure what Seagate Disk Utility is, do you mean SeaTools? That can be downloaded from the seagate website (also includes installation download). As for the disk Utility, what are you trying to do with it, or what do you need it for? If you give me some details I can suggest a program which might solve your problem. Also be sure to include your operating system name and version (IE Windows 3.1). Thanks!
Sep 12, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
My Seagate portable 320gb external hard drive fell on the floor now my computer and laptop don't see it( won't let me get in to the hard drive) , how do I fix this , Important files on it Help please
Since this external hard drive is USB powered and felt on the floor, you could have a broken USB connector or interface card, both located inside hard disk case, you should contact Seagate technical support or repair service, or if you have electronics skills, you could open and check hardware by yourself.
Feb 18, 2011 | Seagate 320GB Portable External Drive ...
Hello.pls my seagate free go version 320 gb harddisk fell down and afterwards its not being detected again on my vista o/s.pls any corrective measure is really appreciated
dropping a hard drive is one of the worst things you can do to a drive specially if it was running. More than likely if the heads crashed against the platers you will need to replace the drive.
Jul 28, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hard drive fell on floor. Now will not
I would send it back to seagate but don't tell them it hit the floor
Jan 09, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Dropped my1TB EXTERNAL Seagate drive, now not WORKING
Probably nothing. Hard drives are delicate machines seeing as th have microscopic lasers that are held by a tiny little arm between the discs. If it fell hard, so will all your DATA
Dec 19, 2009 | Computers & Internet
Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Jul 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Odd clicking noise...
That clicking sounds if ever loud enough is one annoying symptoms of failed disc. When it accidentally drop the reader may come off the disc. It sad to say but you may consider to change your hard disc.
Jun 12, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Slightly dropped seagate external hard drive, recover data??
please use stellar phoneix software
that will do your job surely
Mar 16, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
1,703 people viewed this question
David Payne
David Payne
