Question about Samsung Televison & Video
When I tried to turn on my tv it kept turning on and off now I have to unplug it because it won't stop. Even after I unpluged it for awhile I tried again and it still does the same thing. Thanks for your time Holly
  • 760 Answers
More than likely you have some swollen capacitors on your power supply. These are easy to change, although I would advise that if you do not have any electronic experience you should let an authorized service provider take care of it. It is just a couple of bucks for the parts, but the labor can be a couple hundred dollars. If you are up for it, you will need a soldering iron, solder and solder wick. The caps should be 1000mf at 10 volts or 2200mf at 10 volts. They will be easy to spot out because they will be swollen on the top instead of flat.
Posted on Apr 11, 2011
Toshiba tv won't turn off/ stay on
Try unplugging your television for a half an hour or so. It might reset to original settings, Your problem might be input lock features. If you can get to the menu after unplugging your tv for awhile we might be on the right track. I'm just looking thru a Toshiba manual that I have.
Apr 13, 2013 | Televison & Video
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Sony blinking codes
If i remember correctly ten blinks means a high voltage error.
The only thing you could try is unplugging the power cord then plug it back in and try turning on the tv. If it still won't turn on try unplugging the power cord for five hours or longer and try again. If it still won't turn on it would be best to find a local repair shop that works on sony tv's and have them repair it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-51WS550 51" Rear...
My toshiba tv wont turn on
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
Feb 13, 2012 | RCA F27450 27" TV
My 42HDS69 Hitachi has a recurring problem of not turning on. I unplug from outlet for awhile and sometimes it will turn after I plug in outlet, Other times it takes a few hours for TV to turn back on. ...
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Dec 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Well not turn on. It will flash vertical lines and turn off
post more info to get more help
model#
how many lines and position of lines.
sounds like a bad signal or LVDS cable
Jul 25, 2009 | Televison & Video
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
TV shocked us and now won't work!
1) Try hard reset = unplug AC cords for awhile,then try again.
2) Check with cable company about cable box.......T.
Dec 27, 2007 | RCA 32F531T 32" TV
Tv turns its self on or off at times
I tried to unplug mine for awhile then plug it back in that worked for awhile now it won't come at all. Hope this helps abit, although i'm sure your like me and have tried it all,8)
Jan 17, 2007 | RCA 27F650T 27" TV
Televison & Video Logo
52 people viewed this question
Jerry Greenberg
Jerry Greenberg
