Question about Dewalt Hilti Te 2 Rotary Hammer Drill
TE 2 Rotary Hammer Drill throwing grease from area between chuck and drill. What to do?
  • dsakos Apr 11, 2011
    Where do you purchase a seal kit? Googled it and nothing came up.
    President:
  • 2,468 Answers
You need to split the drill case fuselage into half by removing fuselage screws,then replace the gear case oil seal in the nose of the unit,there are numerous seal kits, they are relatively inexpensive,but you will need to have a full model number off the unit to purchase the correct oil seal kit
Posted on Apr 11, 2011
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
If you have the TE 2 use this manual:
http://www.hilti.ca/fstore/holca/techlib/docs/Tool%20Schematics/Rotary%20hammer%20drills%20and%20combihammers/te_202.pdf
If you have the TE 2-S use this manual:
http://www.hilti.ca/fstore/holca/techlib/docs/Tool%20Schematics/Rotary%20hammer%20drills%20and%20combihammers/te2_s.pdf
You need to replace item 79 that is PN: 354571, Rotary shaft seal AS24X40X7
You can order the part on line here:
http://www.hilti.ca/holca/page/module/product/prca_productdetail.jsf?&nodeId=-38800&selProdOid=139697
or
Contact:
Hilti Canada: (800) 363-4458 Thanks for choosing FixYa,
Kelly
Hilty TE 12 Hammer Drill Wont Hammer, but will run
Parts are no longer available for the TE12. Be carefull if you try to take it apart yourself. Some of the older models had a lead based grease in them
Oct 26, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Hi i have hilti drill machine i dont how to open and removed the drill bit,please help me
what you need to do is twist the collar of the chuck to remove bit and reverse the procedure to lock it into place.
Aug 03, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Will drill but no hammer n
Make sure you have it in the hammer drill mode. To check that it will hammer you can remove the chuck and just run the drill with the front pressed against a wood surface. It should vibrate pretty hard. If this works then you may have the wrong bits or chuck on the drill.
Jul 30, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I nide a chuck for a hilti model te 805 chiping hamer
That chuck is not just one piece. If in the U S contact Hilti @ 1 800 879 8000
Jan 20, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Drill bit stuck in chuck
Grab the bit and see if it will move in or out of the chuck around a half inch. If the bit will not move at all inside the chuck at all. Lock the bit in a vise and strike the chuck with a rubber mallet. This will usually get the bit out.
Jan 18, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
The chuck on my Hilti TE 24 hammer drill keeps falling off. I doesnt appear to be anything broken. Either there is a missing snap ring or I am just not putting it back on correctly. Any suggestions?
the header list 2 different drills, if yur chuck has a colllar with a quick release, I would suggest thoroughly cleaning and then using a lubricant, usually there are steel balls that lock into detents in the spindle and they might be stuck the collar should move freely.
Sep 25, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Where should I grease the hilti 7c
You should not have to grease The TE-7. It is permantly lubricated. You can occasionally put a small ball of grease on the end of a drill bit before you stick in the chuck. This will keep the chuck greased.
Aug 14, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Tip poped off and cant put it back on
IF the whole chuck came off then you just palm the chuck in you hand with the end against your palm,with your fingers pull the sleeve back put it back on the drill. release the sleeve and turn the chuck until it snaps into place.
If it is just the rubber dust protector on the end of the chuck. Put a little grease on it and push it back into place. It is just a friction fit
Jul 27, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
I have a Hilti Hammer Drill model TE5 and I need know grease to use in it
the grease is called turmoil grease and is somewhat expensive. This also requires just about complete disassembly of the tool and smoe parts replacement.
Oct 25, 2008 | Hilti TE 7-C 120V Rotary Hammer Drill
Dewalt Hilti Te 2 Rotary Hammer Drill Logo
209 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
