Question about Evenflo Snugli Front & Back Baby Carrier
I was given an evenflow snigli p.o. 364995 mod No: 0761408A. Below that it says 031706. On the piece of the carrier that is placed next to me and just above the waist straps are two snaps but I cannot see anything that they would snap to. Can you help me?
3 Suggested Answers
connorsmama
  • 20 Answers
SOURCE: Can not adjust the straps
hmm this si a rather old model, you can invest in a new seat for like 50 bucks at walmart!
Posted on Jun 26, 2009
  • 45 Answers
SOURCE: Can not adjust harness straps on evenflow embrace
Evenflo has a GREAT website section on using and installing their carseats. The manufacturer is the final authority on keeping your child safe in their seat: don't accept advice from anyone else!
http://www.evenflo.com/sme_carseats.aspx?id=321
You also ought to have your instruction manual for reference: order it for free, at this link:
https://plweb.evenflo.com/replacement_parts.aspx
Posted on Mar 25, 2010
Where is mod on calculator
Sorry to disappoint you but this calculator does not perform modulo calculations. However you can use the fraction key [a b/c] to enter the numerator and denominator. If the result is given as an improper fraction a b/c, then a mod c=b.
If the result is given as an improper fraction (that would be you input) press [SHIFT][a b/c] to convert it.
On the display integer part, the numerator of the fraction part and its denominator are separated by a symbol as seen on the screen capture below.
Jan 24, 2014 | Canon F-502 Calculator
Making car seat harness larger for child/evenflow discovery 5
You can download this PDF instructional manual for the Evenflo Discovery car seat: https://www.google.co.il/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&ved=0CHUQFjAH&url=https%3A%2F%2Fplweb.evenflo.com%2FShowDocument.aspx%3FManualID%3D583&ei=A8UtUbW5AY_Z4QSCjoDoCA&usg=AFQjCNFj1O1EuRQVLmKwgOLTJsL6yoeOTQ&bvm=bv.42965579,d.bGE
You can also read this article on how to adjust the harness straps on an Evenflo car carrier: http://www.ehow.com/how_6391052_adjust-evenflo-car-carrier-straps.html
Aug 03, 2012 | Baby Gear
Adjusting harness (make it large enough) on discovery 5 evenflow
Aug 03, 2012 | Evenflo Discovery 5 Infant Car Seat - 3...
The bobbin carrier brakes off a piece at the screw area, I hav bough two and it brakes off again and AGAIN .
I would suggest taking the machine to a sewing machine shop & asking them why it keeps breaking
Mar 13, 2012 | Singer Confidence 7467 Mechanical Sewing...
Replacing cartdiges in sx 200 epaon
Press the ink button on the control panel repeatedly. This will work if at least one cartridge is completely out. With the scanner unit open, then the first press of the ink button will move the cartridge carrier to line up the empty cartridge with an "empty cartridge" mark on the printer. Each subsequent press will cause the next empty cartridge to line up with the mark. Once all of the empty cartridges have been indicated, the next press of the ink button will bring the cartridges into the replacement position.
If you want to change a cartridge when none are empty, you need to enter the Epson Toolbox (with the printer in a Ready state - scanner unit closed, etc). Then use the software to set the printer to change the ink cartridges. When prompted by the software, open the scanner unit and follow the directions for changing the ink cartridges.
If the cartridge carrier isn't moving when you press the ink button, look for anything blocking the path of the carrier. Even small pieces of paper could stop the mechanism. Use a flashlight to check the corners. (You may want to unplug the printer and try moving the cartridge carrier by hand to check below it.) Some models have the cartridge carrier run on a plastic strip that can come out of the guide on the back. Move the strip back and up and down until it is repositioned.
I hope this helps.
Nov 12, 2011 | Office Equipment & Supplies
Replacing spoke on the rear tire of a bicycle.
buy a spoke wrench and a spoke for your model bike
remove the tire, tube, and the rubber protection band on the inner wheel
feed the new spoke through the spoke's mounting hole on the hub first
now feed the spoke through the hole in the wheel. you may have to tweak the spoke somewhat to get it in place.
if the spoke is the correct one place the spokes nut to it and thread it on by hand first then use the wrench. tighten it up snug and snig the rest of your spokes with the same tesion a little at a time
Jun 30, 2010 | Cycling
How to remove tail light assembly on 2005 town and country
The step by step procedure is given below:
1) Open the tailgate. Adjacent to the tail light inside the are 2 round, black plastic pieces that hold the light in place. Use a pliers or screwdriver to pull or pry them out
2) The tail light assembly will swing out because the front is held in place by a simple tab.
3) Find the small red plastic piece that locks the wire harness pieces together: slide it to unlock the harness
4) Pull wire harnesses pieces apart, put the new one in it's place, then reassemble.
Nov 08, 2009 | 2003 Chrysler Town & Country
Car seat was given to me without the five-point harness. Where can I get one cheaply?
Sometimes you can find the five point harness in the infant section of a department store or the automotive departments. if not call up evenflows customer service department or website and ask about ordering a replacement.
Apr 23, 2009 | Baby Gear
Lexmark x4270
The 1200 error is caused by a cartridge carrier stall. This can happen if the encoder strip is out
of place.
Please follow the steps given below:
1. Turn off the All-In-One by pressing the power button. Open the control panel and cartridge access
door.
2. Gently grasp the cartridge carrier belt in the area indicated by the blue arrow and move it to the
left
3. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into.
Remove the print cartridges and then gently push the encoder strip down and then back up to get it
into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it
first forward and then back.
4. Reinsert the print cartridges and slide the cartridge carrier back to the right. Then close the
cartridge access door and the control panel and turn the All-In-One back on.
5. Did the error message return?
If Yes, continue to 'Contacting Lexmark' below.
If No, the error is fixed.
Apr 08, 2009 | Lexmark X4270 All-In-One InkJet Printer
Bicycle Child Seat install has a rubber piece hanging in back
The rubber piece is designed to lock the tung on the back of the seat to the rack. To get it in place you need to bend the tung down until you can insert the rubber piece over the tung and under the two fins so that when you release the tung the rubber is locked into place. You will likely need to bend the tung down quite a bit. The rubber piece has two circular ridges that should be between the two fins that it is pressed into. These ridges will prevent the rubber piece from sliding out.
So basically, bend the tung down and press the rubber piece into the slot that is created. It will start to become clear once you get this far. Just make sure those ridges on the rubber are on the inside of the fins.
Mar 12, 2009 | Carrier Cycling
Evenflo Snugli Front & Back Baby Carrier Logo
49 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
