Question about Cooper Wiring Devices Combination Switch & Receptacle
I get reading on load side of breaker but nothing at switches and recepticles.
    Problem Solver:
  • 17 Answers
There is more then likely a broken wire somewheres, its probably in behind a switch/plug/light somewheres... your best bet is to call an electrician and they should be able find the problem with ease.
Posted on Apr 11, 2011
Holmes hch6150 will not produce heat
Without having the heater to tear apart to see what is not working, you may try the following. Your heater is a 1500 watt heater and pulls about 13 amps of current. If you plug it into a recepticle that is already have load turned on, most recepticle circuits are rated for 15 amps and you have probably tripped the breaker for this circuit. Check your breaker panel to see if a breaker is tripped. If it has tripped, this will tell you your pulling to much current. Try another circuit that allows the heater to operate or find the other load on the circuit that is causing the breaker to trip. By the way to reset the breaker take the breaker to full off, this resets the trip, and then turn it back to on.
Hope this helps
Feb 13, 2015 | Heating & Cooling
No power to machine
Check the house circuit breaker. Check the plug in recepticle. Plug a lamp into the socket to test. Let me know.
Jan 26, 2013 | Fisher and Paykel Washing Machines
Make extension 220 volt cord for 220 volt welder
most 220v welders have a NEMA 10-50 plug or the NEMA 6-50 plug--the input /output ratings thru recepticle and thru plug are same-configuration of plug prongs are different( Grainger Catalogue shows simularities and differences) main difference is AC Horsepower Ratings are different, and that applies Only on equipment that uses 3 phase, not your welder.Use an Ohmmeter to touch unpowered wire connection under shroud at ground and plug prong, then red power connection to corresponding plug prong, and again to black connection and plug prong,mark them w/ felt pen w/ corresponding colors (Green, Black Red). Change out wire plug to fit into dryer or stove recepticle, or make an extention adapter plug witch fits stove recepticle and extends out thru floor to carport and goes to 10-50 recepticle-whereas ground green goes to W position (Center) Y is Black and goes to Y Black, X is Red and goes to X red and cap off the white neutral coming from plug -welders and hot water tanks do not return unused electrcity via the white neutral (return) wire--they use up what is available on demand in heating elements or in welders - the electromagnetic field.GET HELP DOING THIS, by someone who has knowledge, SKILLS and EXPERIECE. I have 1 welder fitted to go into dryer plug which has 14-30 recepticle, and i have 1 where i kill stove circuit at panel, unplug stove, plug in 14-50 plug which has a 10-50 recepticle on other end, plug in welder 10-50 -p, flip cicuit breaker switch to on-welder has full power range capacity. No oven in use while welder going--but probably wouldnt run it anyway if on different circuit.Any doubts whatsoever--anything not 100% clear--DO NOT DO THIS or any other Electrical Manipulations--have a licensed electrician stub in a secondary circuit breaker off your main if load is acceptible and have him wire in the recepticle which your plug will fit into---.
May 31, 2012 | Craftsman Welding Tools
I have a George vacuum and it's died. I have
Of course, you should double check the plug-in recepticle - just to be sure you have not thrown a house breaker. The easiest way is to simply plug something else into the same recepticle. If you simply move the vac plug, you may choose another recepticle oparating on the same breaker.
How did you check the fuse? Fuses can fool you. As a general repair tech, I learned long ago not to rely on my eyes. I have a multimeter and do an ohm check - because sometimes a fuse can look ok, but actually be burned in-two where its not easy to see.
All that ruled out, the most common thing that stops functioning when a vac dies is the switch.
Don
That ruled out, when vacs die it usually the switch.
Apr 06, 2012 | Vacuums
FRIDGE KICKS OFF BREAKER
try and plug it into another recepticle the GFI might be bad.
Aug 23, 2009 | Refrigerators
I need instruction manual for a gfci recepticle and switch combin
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
Apr 12, 2009 | Leviton R01-7299-0NI Switch And GFCI...
Pool motor wiring
I assume you mean a gfci recepticle? If this is the case you need to take the black wire from the house and pigtail it to go to both the recepticle (Black / Line) and one line side screw of the switch. The white wire from the house goes directly to the line/white side of the recepticle. Also pigtail the ground to go to the green screw on the recepticle, the green screw on the switch, the green wire from the motor, and the ground screw on whatever box you're using. When you purchase the switch make sure you get a two pole switch rated for at least the amperage of the motor. The red wire from the house and the black wire from the pigtailed black will go to the two line side screws of that switch. The red and black from the motor will go to the two screws on the load side of that switch. Make sure to ground everything properly being so close to water. The cover needs to be sealed securely and I recommend the cover that has the lever to activate the switch as opposed to the little door over the switch handle. Also make sure the two breakers supplying those two circuits have a handle that turns them both off at the same time.
Sep 01, 2008 | Energizer Rechargable Battery with Charger
LG WM2688H Front Load Washer has no power
You may have a failed control board and it will need to be replaced.
Oct 17, 2007 | LG WM2688H Front Load Washer
Cooper Wiring Devices Combination Switch & Receptacle Logo
53 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
