Question about Zanussi ZWF1650W Front Load Washer
Zanussi washing machine zwf 6115 manual - Zanussi ZWF1650W Front Load Washer
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
E20 is "A problem with water draining" Solutions: The drain hose may be squashed or kinked The drain pump may be blocked
Posted on May 21, 2007
SOURCE: E60 error code
Our machine - a ZWF1437 - has developed the same problem. Our friendly engineer has checked his manual and told us that there is no such error code. He suggested switching the machine off and unplugging it to allow any residual charge to clear from the memory chip. The next step is to clean out the filter at the front - remember to empty the water out first. After a couple of hours, switch the machine on, press reset and then spin to empty any remaining water. Hopefully, this could work ---it didn't work on ours but he assures me that this tip usually works.
Posted on Jan 24, 2008
  • 96 Answers
SOURCE: zanussi zwf 1432 w washing machine
Normally when the light above the Start button is flashing it means that the machine is in Pause mode. Then you have to hit the button again to get it to start. If it still doesn't work try the Reset button also.
Posted on Mar 07, 2008
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Posted on Apr 18, 2008
abhishek33
  • 1239 Answers
SOURCE: zanussi zwf 1632 w
hi follow this Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
thank u.......................
Posted on Sep 12, 2008
E20 on a zwf1430w washing machine what does this mean
try this:
http://www.manualslib.com/manual/199539/Zanussi-Zwf-1230-W.html
Mar 08, 2015 | Zanussi Washing Machines
Manual for zanussi zwf 1430w washing machine?
http://www.docstoc.com/docs/1474505/Zanussi---ZWF1430W---ZWF1430W---%28PNC-914517231%29---Manual
Hi go to the above page to find your manual.
If this helps please rate me
Aug 25, 2010 | Washing Machines
My problem is the machine makes a noise as if a piece of cardboard is rubbing at one particular point each revolution of the drum it has now become quite loud on my zanussi zwf 1632 w can anyone help ?
I may just be lucky or it might just be temporary but the fault has cleared on my zanussi zwf 1632 w. washing machine thanks for the offers of help if needed in future i will certainly contact FixYa."Bill 34"
Sep 19, 2009 | Washing Machines
PROBLEM
Its your filter that needs to be emptied; open up the front, locate filter, clean out. Refer to users' manual.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1650W Front Load Washer Logo
78 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
