Kingston 2 GB USB Hard Drive
Problem for Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston USB Device not recognized
By kfj3716 on Aug 07, 2008
I have a Kingston Data Traveler 2GB USB Flash Drive which I bought 2weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices attached to this computer has malfunctioned, and Windows does not recognize it." I tried plugging in the device in other computers but still i get the same message. The OS of the computers I've tried are all Windows XP. The device worked fine for the past week until recently. Is it the device that has the problem or what..?Thanks..
Same Problem
May 03, 2009
-   This drive I have (kingston data traveller 2 gb usb) has always worked like a charm until today. It still works in my laptop, which runs windows xp but when I plugged it into my vista computer it said it installed then did the autoplay. It started to display all the files and then froze up and I could go no further. I need to be able to access these files from my Vista computer because it is my main computer and the data traveller has all my work files on it (which are not currently on my vista computer because I just got the computer back yesterday from the Gateway repair shop).
I did try taking everything off and reformatting it but it does not get picked up after that. Even the status light on it doesn't even light up and no notifications of it show up. I tried it in a different usb port but there was no reaction there either, so I don't think it is the usb port messed up.
I tried searching for driver help for it and the kingston website only has one for windows 98SE, not Vista.-   Guest
Jan 19, 2009
-   does not detect to the computer
-   Guest
Nov 11, 2008
-   same problem-   fixitya
Oct 08, 2008
-   TENGO UNA KINGSTON 2.0 Y NO LA RECONOCE NI SISTEMA, NO POSEO LOS CONTROLADORES-   enanito
Oct 05, 2008
-   I cannot view my kingston data traveler 2GB in my computer. Windows Vista recognizes the drive, says that it has installed the driver? But then i can't find the drive in the my computer.
I have also had problems adding other flash drives to my laptop. However, I can connect my digital camera's sd card throught the usb?
Also I know that the flash drive works as it works on xp. thanks JC-   buckinghamjc
Solution #1
posted on Aug 07, 2008
Somewhat Helpful)
dilipbagdi
Rank: Guru
Rating: 88%, 1413 votes
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
hashchathy
Rank: Wiz
Rating: 79%, 136 votes
I think you have to buy a another data traveler
If you can get this problems in all computer that means it doesn't work and also it can't fix it.
Was this helpful?
Yes
No
Popular Solutions for Kingston 2 GB USB Hard Drive
Questions and Unsolved Problems for Kingston 2 GB USB Hard Drive
Do you recommend Kingston (DTIU3/2GB) 2 GB USB Hard Drive?
Answer
Answer
How to remove the write protection in drive on Volume/Devices/Hard disk/DC6 I need some help.. I... (More)
Answer
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you... (More)
Answer
I just got a generic 16gb flash drive and just about every media file i copy there gets corrupted.... (More)
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Sep 25, 2008
With my 8gb Kingston DataTraveler
Comment by Guest, posted on Sep 10, 2008
very good
Comment by vogrady, posted on Sep 07, 2008
I have a Kingsotn 2 GB USB flash drive. I works in my home computer, however when I plug it in to my work computer, and try to open it, I get a message that says Please insert disk into drive e.
Comment by Guest, posted on Sep 06, 2008
kingston 4gb dti100 not recognized
Comment by dandugi, posted on Aug 18, 2008
I have the same problem, and I have tried it in about 20 different computers. It only works in half of them, and I get the "not recognized" error in the other half. The error always shows up on the same computers, and always works on the same computers, it is not random. All PC's run XP SP2.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
