Question about IBM ThinkVision L170 17" LCD Monitor
IBM LCD Monitor Model # 6734-ABO
Hi! How are you? This monitor was working perfectly when suddenly, No picture... Like the other posts pointed out, You can shine a flashlight at the screen and see the image, so something is wrong with the backlighting circuit. Now I have to assume that "caps" is an abreiviation for capacitors... There appears to be one board for graphics rendering and one dedicated to backlighting. I am an auto mechanic, not an elecs tech, but I would think if the problem were the back light bulbs, then all of them would not fail at once, correct? I have looked for a fuse in this unit and found nothing that resembles a conventional fuse anywhere. Is there a schematic available anywhere for this unit? What would the fuse look like? Which capacitors are responsible for the backlighting circuit? Thank you very much. Would just buy a new unit but am totally broke.
Adam Drennen
  • greatfull Oct 23, 2008
    same problem have you found a solution yet?
How would u test the capacitors on what setting?
Posted on Oct 04, 2008
    Champion:
  • 293 Answers
Adam,
Well, to look for a bad capacitors you need to tested with a ESR meter. But if you are lucky sometime you can spotted just by look at the top of a caps for stress mark (like it going to burst out). The caps look like a tiny battery, other look like a blue button with 2 pins. Sometime it not the caps problems...it's beyond repaired. Anyways, good lucks!
Posted on Oct 03, 2008
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
Moniteur thinkvion 6734-ab0
i had the same trouble i changed 2 capacitors on the power supply board a 470uf at 25 volts and a 1000uf capacitor 25 volts.look for any capacitor where the top is bulged and replace them. my monitor works great again.
Jun 22, 2012 | IBM ThinkVision L170 17" LCD Monitor
How can i fix the continous on & off blinking of my ibm l170p monitor
If your monitor is blinking or flickering increase the refresh rate.
Apr 07, 2012 | IBM ThinkVision L170p 17" LCD Monitor
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
Monitor IBM thinkvision 6734-ACO 17", turn OFF
Sounds to me your high voltage powersupply is out. To repair open monitor and remove high voltage powersupply. Inspect the caps on the board. Look for the ends of the caps to be mushroomed out. Replace these caps, usally 470 uf caps. Replace with 25volt caps. Might also be some 100uf caps as well. This is a common problem with all LCD monitors.
Jul 22, 2011 | IBM Computers & Internet
I have an image with the flashlight, but no backlighting on my IBM 6734 lcd monitor
The inverter module is bad or the back light behind the LCD screen has stopped working, I would suggest an estimate if you decide to have it repaired.
Jan 22, 2011 | IBM ThinkVision L170 17" LCD Monitor
Need a service manual for an IBM 6734-HB0 Monitor
MY IBM monitor is very dark screen even in setup menu at the start
Jan 26, 2010 | Computers & Internet
Lamp cicuits in lcd monitor
AnBparts ebay store is very helpful.
They have this IC in small qty.
I've made several purchases from them and they are very reliable.
Here's a link:
http://cgi.ebay.com/AO4600-4600-POWER-MOSFET-INVERTER-PARTS_W0QQitemZ370160819357QQihZ024
Thanks,
Chris
Boise LCD - monitor repair
www.BoiseLcd.com
sales@boiselcd.om
Mar 16, 2009 | Computers & Internet
LCD flat panel monitor blinks logo over and over
Sounds like the LCD monitor is not getting a proper input signal. Check your cables between the computer and monitor. Replace them if need. Also check the pins and make sure that none are bent or disfigured.
Try a replacment monitor from a family member or friend. If their monitor works ok.....then your due for a replacment. The are very little user servicable parts inside.
Jan 23, 2009 | IBM ThinkVision L170 17" LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
IBM ThinkVision L170 17" LCD Monitor Logo
855 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
