Question about Garden
Briigs stratton $%) mower starts fine then looses power and chugs. does not retain enogh power to cut the grass. Power increases when air blown into the carbureta. Duncan
  • 2,510 Answers
Check the valve clearances. There is no adjustment for the valves and they do dig themselves into their seats. File the inlet valve to give it a slight bit of clearance, about 0.005". Leave the exhaust valve just touching the tappet to act as a valve lifter for easier starting, The valves and tappets are accessed through the cover in the crankcase under the muffler.
Posted on Apr 11, 2011
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Kohler courage v twin 22 hp on my Troy built Ztr starts fine but loses power when cutting grass
bad valve seat needs valve job motor is overheating looseing power or under load
Aug 06, 2014 | Garden
I have a 4 month old mcculloch with a briggs and stratton 450c engine , it starts no probs but then starts to blow out black smoke
Hi, check your air filter, also check your oil level is not over full as it may have become diluted with fuel. Let me know. Regards Phil.
Aug 30, 2012 | Briggs & Stratton Briggs Stratton...
Briggs and stratton 6.5 started smoking so changed oil in hopes would help still smoking
sounds like it broke a ring to fix better to buy new moter not worth trying to fix
Jun 01, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Craftsman Platinum 190cc 22" Briggs
hi there
danielburgi
1 almost sounds like you may have a restriction in the main jet of the carburettor or idle circuit transtional holes or idle air bleed holes , also check emulsion tube
2 then if these are all ok try adjusting governor - as soon as load exceeds power output - unit will try and stall- once governor adjusted re-try -
3 the only other thing it may be is too low compression which ia major concern
try 1 and 2 options 1st
3 is the last option which means a leak test to check compression loss or worn rings
cheers pauly46
hope it helps
May 27, 2011 | Garden
When I lower the blade deck on my Troy Bilt mower
If it is a 2 cylinder with a set of bent valve push rods on one side it may well start and sound good, but it will not be able to do the work as only one cylinder is functional. I had a similar problem on a B&S V2. Pull the plug wires off one at a time. If it makes no difference with one plug wire off and is totally dead with the other plug wire off, then you have a dead cylinder.
Jun 26, 2010 | Briggs & Stratton Garden
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
