Question about Frigidaire Microwave Ovens
I received an upright Frigidaire Freezer from my parents due to moving and they couldn't take it with them. The model no. is LFFH2067DW2 Serial No. is WB70827921 . My problem is I didn't get the book or manual with it. It has been running constantly since Friday evening when I plugged it in and it won't shut off. The Ice cream is really soft and won't seem to freeze hard. Is there something I can do or maybe I'm overlooking something. Please help!!!!!! Thank You, Wanda
  • 1 more comment
  • wphillips691 Apr 11, 2011
    My freezer was not moved on it's side. However it was tilted to get it through the doorways.
  • wphillips691 Apr 12, 2011
    Thank you. I unplug it so I will try this and again thank you for your help.
  • wphillips691 Apr 13, 2011
    I tried unplugging for 24 hours and I plugged it back in. The alarm sounded and all the lights were on. I shut the alarm off and it has been 14 hrs. that it has been plugged back in and it is still running and some of the stuff inside is thawing out. What else can I do? It doesn't have a temperture control knob to turn it up or anything only a box for temperture control sensor.
  • 8,197 Answers
You can get the manual on the link below. Also if you moved the freezer on its side you will have this problem. You need to un plug the freezer from the wall for 24 hours to let the freon get back to the bottom to make work again.
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216960000en.pdf
Posted on Apr 11, 2011
  • Jyackle5
    Jyackle5 Apr 11, 2011
    If the freezer was tilted more than 45 degrease you still need to let it stand up for 24 hrs before you plug it in.
  • Jyackle5
    Jyackle5 Apr 12, 2011
    Your welcome please let me know how it goes
Electric frigidaire stove model:RE-38S serial :61CD4495 oven wont heat. checked;continuity,cord,wiring and outlet all was good. how do i fix this problem?
can not say as do not know if it is a conventional stove oven or a microwave oven . I would call a local repair service
Sep 13, 2017 | Frigidaire Microwave Ovens
How can I remove door?
Hello friend, thank you for your inquiry!
From my understanding you need assistance removing the door from your Frigidaire microwave. In order to assist you further I would need to have your model number. You can locate the serial tag (which lists your model number) on the inside left had wall. Once I have that information I would be able to look into any available information for you. -Matt
Feb 05, 2016 | Frigidaire Microwave Ovens
How do I tighten the door handle on a Frigidaire over the range microwave oven?
You need to remove the inside part of door to gain access to mounting screws.
Nov 19, 2015 | Frigidaire Microwave Ovens
FrFMB136G1Bigidair model numbers
Hi Friend, thank you for your post!
I see that you have a Frigidaire microwave, FRFMB136G1; however, it appears that your model number is invalid. You can typically locate the serial tag (which lists your model number) on the front of the oven, in the lower left corner as you open the door. Are you seeking an Owner's Guide or is your microwave experiencing an issue? Please describe what your appliance is doing so that I can assist you better in pinpointing the problem. Thank you! - Z
May 18, 2014 | Frigidaire Microwave Ovens
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
We have a frigidaire model number frt045gb upright freestanding fridge and the light is on inside but the motor isnt running,it is warm in the freezer and fridge part
Since the light comes on, but nothing else runs, check the defrost timer. If it is stuck in the defrost cycle, the light will come on, but nothing else works.
BGA
Apr 19, 2011 | Microwave Ovens
I have a model plmv168kc2 serial pg13903700 frigidaire microwave\r\nthat made zzzzz noise then quite heating , every thing else seems to work but willnot heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Apr 19, 2011 | Frigidaire Microwave Ovens
Water is leaking on then freezing on the floor of my upright frigidaire freezer. At first I just thought it was a fluke and cleaned it out, but he next day their was frozen water again. I also am finding...
Your freezer goes to a defrosting cycle and actualy melts away some ice formation inside the freezer, normaly this melted ice (water) drains trough a tube in the back of the frig... the drain is probably clogged and the water spils out... to unclogg it you need to find the uper end of the drain (where the water drips in) usualy way in the back of the frigidaire, than try pushing a long wire in downwards to unclogg the drain, also check underneath or in the back of the frig. ther should be a back to hold the water for the time it evaporates, see if it is not full of water or dirt (dust) i even foud some pet toys in there once ha! ha!
Hope this helped!
Mar 02, 2011 | Microwave Ovens
I have a frigidaire pro series micro wave built in undercounter serial number 7g61910011, I am moving and want to know how I can uninstall..the store personel who installed took the install manual..and I...
Your model number will be on a tag inside the cooking cavity or around the control panel frame or door frame.
You will need that number.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
Nov 25, 2009 | Frigidaire Microwave Ovens
The compressor does not work well and the bottom part emits heat
open door to the freezer and look in the back of the freezer and see if there is ice or frost building up,if so you have a defrost problem.it could be a bad timer or bad defrost heater or bad thermal switch.you nead a continueaty meater to check them out or call for a service call.
Nov 15, 2009 | Microwave Ovens
Microwave Ovens Logo
44 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
