Question about Maytag Refrigerators
I have model MSD2356AE . how old is this fridge? The freezer doesn't seem to be as cold as I would like (icecream to soft) unless I turn it past the midpoint.
SOURCE: Fridge is not cool. Freezer has soft ice buildup inside
Losen up the 2 screwws on the back inside of freezer.
push the back slash up and pull down on the top of the plastic fan cover, thats the secret getting the fan cover off its a snap on. Don't break it. but once the cover is off you can see your frozen ice hole under the condenser I used a hair dryer (not recomended near water)and it got the ice melted. worked great.
No more bad milk,,Saved big bucks with alittle good advice, thanks
Posted on Mar 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
Healeyman
  • 1198 Answers
Setting the control to 9 may make the freezer ice up too much to work right. You can start with a manual defrost. That takes a long time, because the ice is below the freezer liner, stuck in the coils. You'll have to move your food elsewhere, like a cooler. I always take the freezer apart to get at the coils, use a hair dryer to melt the ice. Then you can check the defrost coil, it's like a toaster element. After all that, check the defrost timer too. It's usually down by the compressor area, about the size of a cell phone. It has a small dial on it that only turns one way. Mark it when the fridge is on with whiteout to see if it moves. It moves real slowly, so you will have to wait a half hour or so.
One way to speed up a defrost is to turn the dial on the defrost timer until it clicks. Then the compressor will turn off and the defrost coil will turn on. The freezer fan should be spinning. Feel the output from the freezer fan- anything? If no flow, you're iced up. Keep checking for flow, eventually it should get cold. When you get good airflow, and maybe it's not so cold anymore, you might be defrosted without having to take the whole thing apart. You may have to turn the dial more than once, if the compressor comes back on before you're defrosted. You can help the defrost with your hair dryer thru the vents in the front of the freezer, but not too hot, you don't want to melt any plastic.
Sea Breeze
  • 4655 Answers
SOURCE: Both Fridge and Freezer quit working properly at the same time.
I will need the model number as shown in photo below where the locations are most likely to be. While I am waiting I am going to go over some models like yours to see what may possibly be wrong.
http://servicepartstec.blogspot.com/e6dabfb.gif
Posted on May 26, 2009
  • 18 Answers
SOURCE: Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
Posted on May 29, 2009
Both fridge and freezer are turned up to maximum cooling but they just aren't cold enough even though the weather is mild. Icecream is very soft - barely frozen and fridge temp is about 8 degrees...
Sounds like a failure to defrost.
Look on the freezer rear wall inside the freezer for ice bukdup.
If there is ice the defrost components ,must be replaced.
Dec 01, 2010 | Fisher and Paykel Active SmartĀ® E522BR...
I have a Bosch Refrigerator at my church that is not cooling on the Refrigerator side, it is a Model # B20CS50SNW /02. I am an electrican but not an applance tech. The blower fan for that side is not...
Generally the fans use line voltage, but if you have a controller board and are getting 12 Volts this would be the correct voltage. The problem is the fans. You will need to replace these fans and defrost the freezer and fridge. When the evaporator coils have frozen overdue to insufficent air flow then no fan will be able to cool the fridge. So make sure that once you replace these fans you get a good defrost for at least 8 hours. Unless you use a hair dryer or heat gun to speed up the process. You will find that these fans are about $52.00 each and trying to repair or fix one will only result in a second repair.
Aug 04, 2010 | Bosch Refrigerators
Maytag fridge MSD2356AE freezes vegetables in the produce crisper.(center crisper). Freezer and fridge settings both at Number 3.
Click Here=> Service Manual MSD2356AE I believe you are having problems with the auto damper 61005993 or 1005661 Auto damper.
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Feb 25, 2010 | Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer problem
Thank you for your interest. I had to call a technician who fixed the problem.
Jul 21, 2008 | Refrigerators
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
