Question about Zanussi Washing Machines
Hi, I have a Zanussi ZWF1210W which the drainage pump has gone. I know that I can oder a new pump for about 40 pounds. However I cannot get the old pump out! It looks like a special triangulated key should be used to release the plastic housing that appears to fix the pump onto the base of the machine. Also there does not seem to be away to take the back off the machine so we had to lay it on its side which we then found was against advise. Is it possible for me to do this repair which looks quite staight forward for other makes of machine or do I HAVE to get an engineer to do this?? Help, many thanks. Judith.
  • 641 Answers
SOURCE: how to fit drive belt to zanussi washing machine
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
  • 66 Answers
SOURCE: Admiral Washer Model#LNC6762B71
if water leaks in the tub your water valve need to replace. and thelower bearing. i can let you know how much the parts are.and valve is not hard to replace but bearing is
Posted on Feb 18, 2008
reddevil6
  • 1673 Answers
SOURCE: VACUUM REPAIR
There are 2 tabs that stick out on the release, they fit in slots, so from the top look down and you can see them, using a flatblade screwdriver that will fit in there, push the side in to release it, which isn't easy, but it can be done. When you get the old one out, then the new one, push down on it until it locks into place.
Posted on Mar 06, 2008
TampaNative
  • 778 Answers
SOURCE: Hi.. hope you can help
Hi Hettyboddy,
I found this how to (below) on drum bearing replacement for your specific Zanussi washer and edited it to just reflect the drum removal part.
Power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum.If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Refitting is, as they say, a reversal of the above process. You do need to have significant mechanical skills. If you're the type of guy/gal who works on their car, it would be no problem, if you're a novice, I'd pass.
I wouldn't think that the offending object would make it to the pump, but would probably want it out myself as that is a very nice washer (highly rated). and the idea of having something rattling around in it would be annoying to say the least.
I hope this helps and Good luck.
Posted on Mar 18, 2008
Lumpy816
  • 246 Answers
SOURCE: Leaking washing machine
Jan, if your pump needs to be replaced, I haven't seen a step by step instruction on it so far, so I hope this will do. First Unplug the machine and remove the remaining water from inside of it.(even after the spin cycle, water remains inside the bottom of the tub, the pump and the drain hose) The easiest way to do this is using a wet /dry vac, attaching it to the end of the drain hose that goes into the wall and sucking the remaining water out. Next pull the unit forward and tilt the top of it back about 45 degrees. (when you have it tipped back far enough, the top will rest against the wall behind the machine instead of tipping forward) Remove the belt from the pulleys underneath the machine. Remove the 3 bolts holding the pump to the base of the machine. Use a pair or pliers or channel locks to remove the clamps on the hoses attached to the pump. Install the replacment pump you've purchased from a local appliance parts sttore or bought from the manufactures web site on line by reversing the process. Run a quick fill/ spinto make sure you have no leaks.
Posted on Jun 17, 2008
MY zANUSSI zwh6140P IS LESS THAN A YEAR OLD AND IS JUST OVERFILLING WITH WATER AND WONT DO ANYTHING ELSE
It could be a blockage in a outlet pipe or in the filter or pump. The machine won't advance the program until it knows the water is gone.
Dec 23, 2012 | Zanussi Washing Machines
My zanussi 1000will not pump out water
Check the drain hose.If its squashed or kinked,it may cause drainage problems.
Check the drain filter for clogging.
Ken.
Jan 22, 2012 | Washing Machines
My Zanussi IZ 161 washing machine has a dreadful smell! I've tried completing a high temp wash and using soda crystals but it keeps on smelling and although it washes the clothes well, if you leave them in...
hi ,well its the wee door down at the bottom right ,open that and loads of water will spill out,it will stink,mop up water and clean out drainage,that should do it,its a simple job and it willl save u pounds,it is just a build up of smeelly water
Jan 09, 2010 | Zanussi IZ161W Front Load Washer
Gianni Dishwasher won't switch into cycle and just hums.
I have found out that it seems to be the drainage pump, have real problem finding a new one.
Jun 03, 2009 | Zanussi 24 in. LS6E Free-standing...
Won't spin
hi..
What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11)
just pull the board u can discover burn thru on r11 (you can see the blackened resistor). orders and new board & wax motor on ebay. open the washer & replace the board & wax motor..
thank u
rate me!!!
Apr 13, 2009 | Zanussi Washing Machines
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Drain pump for washing machine
the pumps vary a lot but if in the uk, pump cost is about £25 and fitting about £40 but why do you need a pump?
Oct 22, 2008 | Zanussi IZ12 Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
