Question about Whirlpool Duet GHW9150P Front Load Washer
Will not spin saying f6 - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 19,396 Answers
Hi.
F06 is telling you that the sensor that detects the motor speed is returning an incorrect value.
Here the full troubleshooting:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
? Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
? Check the Drive Motor
? Check the MCU
? Check the Wire Harness
In simple words the technician must check if motor is working by Ohming it or energizing it. If motor is good he must test the Tachometer, which is located on the motor shaft. The sensor is part of the motor assembly and it is tested checking its wiring harness and the harness between washer's control module. A direct test on the sensor is done by the washer when F06 is returned.
The wiring harness connector on motor is as in pic below. Tech checks continuity in wires 4 and 5 going to CCU:
The repair must be done by a technician.
Since the repair is quite complex, I suggest disconnecting power for five minutes (trip circuit breaker) and running a new cycle. If problem comes back, call the number listed on the user manual to contact a qualified technician.
Regards.
Ginko.
Posted on Apr 25, 2011
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
Maytag front load washer mod mhwe251yg00 cde e1-f6
Serial communication error you have two computers one up top the CCU and one down below the MCU it's saying the two are not talking to each other the tech sheet has you go thru about 20 steps to basically come to the same conclusion it's either one or the other which I could help more but I run into the same problem in the field. Most times it's a failed CCU
Jan 20, 2014 | Maytag Washing Machines
F6 error on Hitachi washing machine Sk 120KJS
Jul 09, 2012 | Washing Machines
Cannot get a spin cycle, washer gets stuck before spin cycle get F6 error code
You will need to access the drain pump first by removing the bottom panel. Open clean-out on pump and check for obstructions. If none, the pump may have a broken rotor, these are the problems related to the F6 code.
Dec 01, 2010 | KitchenAid KHWS01PMT Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
He 3t error code f6,washer will not spin,door will not open
"f6" error code means that there a miss communication between mcu(motor speed control board) and ccu(central control unit). i recommend you to ohm out the motor. most likely its your motor speed control located at the bottom left of the washer good luck. replace the motor speed control board and you should be all set to go.
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Motor Fault
check the carbon brushes on the motor or it can be a motor fault also change the belt at the same time
Apr 25, 2008 | Asko W6021 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
223 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
