Question about Dryers
Miele Dryer T1333 Diagnostic test - Dryers
  • jayveebol Nov 03, 2008
    It beeps and doesn't start
  • lnowak7505 Jan 22, 2009
    my miele t8005 dryer stops and re-starts during the drying cycle
Miele front load dryer starts drying & stops & starts beeping
Posted on Sep 24, 2008
Hi, My dryer does not get hot anymore. its blows cool and takes 3 hours to dry now. any suggestions. Clint is clean and not blocked also
Our Miele 9800 dryer didn't heat and we called the service technician from Miele. Our thermal elements needed to be reset. Pull the plug before you do this. Take off the small back panel with a phillips screwdriver. Reset the the three thermal elements. Put the cover back on, plug in and try again. A Miele is like owning a Mercedes Benz or a BMW. This is a high technology German product that needs attention at times.
Jul 18, 2011 | Miele T9800 Electric Dryer
Miele t224 tumble dryer is broken. the problem is how to access the drive motor and drum
Mar 06, 2011 | Miele Novotronic T220 Electric Dryer
Our Miele dryer gives a clicking sound each turn of the drum. But when in hold mode: pausing, reversing, then rotating -- there's no clicking sound. Is this normal, or time to call a Miele repair person?...
Hello & Welcome to FixYa
The clicking sound that you hear can be caused either by the timer going bad or the electronic board itself has gone bad. As the dryer works when in hold mode the problem can be with door switch or the motor relay. There are some tests involved that should be done in order to verify which part has gone bad, so you know its always better to get this checked by a tech. so to avoid any add on charges. Please get back to me if you have any other questions.
Dec 02, 2010 | Miele T9820 Gas Dryer
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
How do i replace the dryer belt on my t9820 miele gas dryer
Don't mess with it. Call Miele. The front seal is probably worn and caused the belt to break.
Feb 04, 2010 | Miele T9820 Gas Dryer
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Jun 26, 2009 | Miele Novotronic T230C Electric Dryer
Clothes not drying - fan ok, heat ok
I just had a Miele tech fix this. There are several causes for this. One cause is a motor fault with the fan motor or a bad belt. Second issue is a blocked up condenser. Finally the issue is electronic and the electronic panel needs to be replaced. The electronic panel consists of small relays that can burn out.
My issue was the electronic panel.
To test a blocked up condenser, is to take the top panel off, and spin the fan motor (by hand). If you feel resistance, you have a clogged condenser which must be replaced (Always run 'Remove Fluff' cycle so this never happens after every dryer use).
To test the fan, take the connector off and 'carefully' connect to 220v to the fan motor (checking polarity). Only do this, after you reset the switch (found in the rectangle box in the middle of the Miele metalwork on top) and made sure the fan does not work automatically when a drying cycle is selected.
The most expensive repair is the eectronic module which costs £175 plus £99 Miele callout.
Apr 22, 2008 | Miele WT945 Front Load Washer / Dryer
Dryers Logo
440 people viewed this question
Top Dryers Experts
