Question about Tyan S7002 Motherboard
We have a TYAN S7002 motherboard that we just bought. It does not power up immediately and sometimes after disconnecting and connecting the components it powers up. Once it powers up if it turns on and we turn it off it does not come back on. In the times that it does not come on. We here a click from the power supply but not a single fan turns. After about 1/2 hr or 45 minutes it will come on and everything (the fans, etc) power up immediately. Originally we put in an Cooler master UCP -1100W initially and then we put in another power supply (Cooler Master RS850). And we have not been able to power it up.
2 Suggested Answers
  • 1019 Answers
SOURCE: Manual to tyan s239001
Try This link to Tyan Archive Files.
http://www.tyan.com/archive/support/html/manuals.html
I think your board will be here.
Trinity KT Manual under Socket 462/A ( AMD Athlon/MP/Duron )
Mike @ Compurepair.
Posted on Mar 12, 2008
How do i reset the password on a Tyan m3296 SMDC
contact Tyan and request support, just say that the hardware was in a machine you were given. It might be that that there is a generic password built int the firmware. Such a practice is common on most electronic equipment, hope you are lucky. Otherwise look for an answer on Tyan forums or Tom's Hardware
Mar 14, 2015 | Tyan Computers & Internet
Motherboard tyan s5167
here you go http://www.tyan.com/support_download_manuals.aspx?model=S.S5197
May 18, 2014 | Tyan Computers & Internet
Code ff on boot s4881g2nr
This is usually the hard drive is bad.
Apr 23, 2014 | Tyan S4881G2NR Motherboard Server Boards...
Need to replace tyan motherboard s2090, could
It appears that any Pentium 4, ATX formfactor motherboard will do you. This ought to get you started, but make sure it will fit inside your computer. Don't skimp on the research.
Jul 29, 2010 | Tyan Trinity S2090 Motherboard
Tyan s2720 was working fine. cleaned fans and fiters then when I tried to boot up no bios and 7 beeps pause 7 beeps pause 7 beeps etc...
Hi:
Check and see if somehow your video card came unseated from the motherboard. sometimes just moving a tower around can pop them loose.
Nov 12, 2009 | Tyan Thunder i7500 Pro S2721UGN...
Computer keeps re-booting while installing any operating system
Were the two power supplies you tried inclusive of the original failed drive or not. In other words did you try a total a 3 power supplies including the one that failed?
If not, please do so. That is, immediately analyze the original known part failure, the power supply or its connection to the board(s) you have tried.
Congratulations for such an exhaustive process of elimination.
Apr 21, 2009 | Tyan Trinity S2090 Motherboard
Tyan S5396 and Thermaltake 1500W
tyan i5400xt.. to test for ground.. pull the board from the chassis and test with a different known good power supply
if the boot works... then you have a power supply issue...
does the board have a post code lighted signal ???
if so.. a bad power supply should goto FF error code
verify you have enough power on the cpu rail with your power supply specifications also
be sure you have all cables 4 pin 8 pin and 20/24 pin connections done correctly.. lastestly check if the board is touching the chassis edge anywhere... could cause a ground
also take and loosen all the MB screws from the chassis.. just let it hang there this will test the grounds needs the screw connections
mark@omces.com
tyan specialist
Oct 31, 2008 | Tyan S5396A2NRF Dual LGA771 XEON5000 5100...
Tyan le s2510 reconnection to case panel
If you go to Tyan ftp site ftp://ftp.tyan.com/manuals you should have no problem finding the .pdf version of your manual with all jumper and connection settings. I would do so quickly, as the company is making changes to the website. Also, if you look very closely the front panel connections are usually printed on the board but can be difficult to read.
Sep 22, 2008 | Tyan Thunder LE S2510 Motherboard
Mike @ Compurepair.
Mar 12, 2008 | Tyan Thunder n6650W Motherboard
Front usb
In case you don't have it, here is the manual for your motherboard: ftp://ftp.tyan.com/manuals/m_s2090_100.pdf Unfortunately, this motherboard does not appear to have USB headers on the motherboard itself so the only way that you can connect up the front motherboard headers is by getting an USB PCI card that has headers on it. Something simillar to this: http://www.newegg.com/Product/Product.aspx?Item=N82E16815108107
Jun 19, 2007 | Tyan Trinity S2090 Motherboard
Tyan S7002 Motherboard Logo
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
Andrew Taylor
Andrew Taylor
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
